Old 06-20-2011, 01:46 PM   #449
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
I've put one in for the fresh tank too, I think it'll work just fine.
We are looking forward to getting homemade getting on with the last six weeks of work
truckasaurus is offline   Reply With Quote
Old 07-05-2011, 08:34 PM   #450
1960 33' Custom
Desperate times
Well we're at the five weeks to go point and it's not looking like there's much wiggle room in the schedule. We did just get the shower tub installed and sealed up which is a big landmark, a little plumbing on the exit side and I can move onto the supply side. I've booked the 'stream in for some professional tlc, a local RV dealer is going to install the propane lines and regulator for me which will save a little time and help me sleep at night.
I'm a bit stumped with the city water regulator; I'd kind of assumed it would attach to the city water inlet inside the trailer between the inlet and the fresh plumbing system but it seems much bigger, what gives?
After a thoroughly terrible experience with the Honda Power Equipment dealer in Calgary I bought an EU3000is generator from another dealer in Edmonton. So far I've just run it for an hour as I'd like to get the 20hr oil change out of the way before I go on a big trek and I really like it. It's super quiet but is a bit large and may require some rejigging in the truck bed area. Now I need an air conditioner to justify the huge red toy.
ID:	134064   Click image for larger version
Old 07-05-2011, 10:43 PM   #451
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Those are some fancy valves there in the shower... I like it!!
Darkspeed is offline   Reply With Quote
Old 07-24-2011, 08:51 AM   #452
1960 33' Custom
Down to the wire
So, a couple of weekends to go and there's more than a few jobs still to take care of, mainly finish cabinets, install flooring, doorway (build door too), wire and plumb to finish, complete dinette table and pedestal unit, source all essential stuff like hoses, install genset in truck, install AC unit and cooling system ducting and circuitry, fab and install screens and maybe hit the weigh scales and do a bit of balancing and if I'm lucky test run the plumbing before 3 weeks on the road.
This week I had a local RV place install the propane lines, they did a nice job if a little pricey (over $1100 reduced to $800 after my nearly croaking on the spot). I also picked up the dinette upholstery and the GF stuffed them all with foam and Dacron and they look great. We also picked up the screens which had taken $400 and 3 weeks only to find that a one legged cat could have done a better job so they went straight back :-( So Fraserway RV gets a thumbs up Airdrie Windshield and Glass gets a huge "avoid like the plague thumbs down".
I also found a neat 1 1/2" Y valve at WestMarine that mounts flush so we can switch pump out from black to grey easily, pricey at $70 but at this stage money is pouring into parts like there's no tomorrow so I'm trying not to dwell on it too much.
The drawer and panels are going to get trimmed to final size today and laminated with a sculpted Formica P lam.
ID:	135728   Click image for larger version
ID:	135730   Click image for larger version
Old 07-24-2011, 09:03 AM   #453
toastie's Avatar
1955 22' Safari
Great Lake State , .
Wow, just fell off the chair, looking great!!!!!!!!!!
toastie is offline   Reply With Quote
Old 07-24-2011, 09:09 AM   #454
1960 33' Custom
You're telling me. When they said 7 hours at $130 I suggested they get some new techs... Welcome to Canada Nice guys though
Old 07-25-2011, 07:20 PM   #455
1960 33' Custom
getting closer
A few small wins this evening. I finished trimming and laminating the drawers and panels; added support rails for the dinette to hold the table in place as a bed platform and slipped the fridge in for a test run.
The fridge is uber quiet and the Danfoss compressor doesn't even seem to get warm; it chilled a couple of Keiths down pronto. I'll have to do an ice making test and time it next.
It's a little hard to see but the Formica skins on the drawers have a really neat pattern in the material.
After work tomorrow I'll be trimming the dinette table with aluminum and hopefully starting on flooring....at some point I'll have to take care of the plumbing and wire up the distribution panel but that parts a little daunting.
ID:	135929   Click image for larger version
Old 07-25-2011, 07:52 PM   #456
Baltimore , Maryland
7 hours at $130 Welcome to Canada Nice guys though
Man I need to raise my rates!!! I will say that 7 hours to do the whole job is not too bad though. Flaring lines is not always an easy task.
Old 07-25-2011, 07:57 PM   #457
Darkspeed's Avatar
1972 31' Sovereign
Looks really good and dig the fridge!!!
Old 07-31-2011, 07:21 PM   #458
1960 33' Custom
So, not a bad couple of days. I ran all the PEX and installed all the 1 1/2" sanitation hose that the black and grey system requires. I'm almost stunned at how much all the fittings, pipe, hose and stuff has added up to. The good news is that after a couple of false starts the vacuflush system seems to work; quite a relief.
We fitted one of the 1" venetian blinds and it went great but I did break a weld on the window closing it so I'm going to have to take it in to work and see if it can get a tack weld or something.
I've noticed the door knob is starting to perform poorly to the extent that I'm sure it won't open from the outside soon. It was replaced with the correct new assembly when I bought the trailer 3 years ago but I'd love to ditch it and get something better. I don't particularly care for the appearance so keeping it stock is not important to me and I wonder if anyone has found something less finicky that works for a slim yet set back scenario.
Tomorrow it wiring day and if that goes well a full fresh water through to dump test; fingers crossed...
ID:	136422   Click image for larger version
Old 08-01-2011, 07:32 PM   #459
1960 33' Custom
Just desperate
Some days it just doesn't go that well.
I tried to get the wiring done but hit some roadblocks.
Attached is a picture of the Progressive Dynamics Power Control Center PD4045.
I've attached the 110V shore power (fat wires) and the main breaker and branch circuit for the converter along with battery wires to a temporary 12V battery. It does nothing; I kind of expected the fan to spin up as it charged the battery but it twitches a few degrees when I flip the breakers off and I'm stumped. The instructions are useless and I'm hoping someone out there has this figured out already.
Old 08-01-2011, 07:53 PM   #460
Bauxter's Avatar
1973 31' Sovereign
Columbus , Ohio
Not to be a smart-aleck, but is the power on? What voltage is coming over on the shore power?
Bauxter is offline   Reply With Quote
Old 08-01-2011, 08:53 PM   #461
1960 33' Custom
Shore power is on. I didn't check the voltage but it was straight from the garage so 120V give or take. I tried grounding the "-" battery terminal in case that was it but no luck. I'll try a call to their help desk in the morning and try and move on from there.
Old 08-01-2011, 10:27 PM   #462
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
The fan nudge is a good sign - have you loaded the controller so it starts warming up? 24/7 fan is maybe not needed as there could be a temperature limit to kick fan on, or a variable speed fan on sensor heat-load demand?
factory new shell- 2007 Classic? boondockdad 2006 - 2010 Classic (all lengths) 18 09-04-2014 07:39 PM
How big a shell off has been done? tbrom Repairing/Replacing Floor &/or Frame 1 10-12-2006 09:45 AM
Shell on or off??? Bradjun1 Repairing/Replacing Floor &/or Frame 3 09-19-2006 11:19 PM
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 05:46 PM
Replacing the shell ?? William8979 Repairing/Replacing Floor &/or Frame 2 05-11-2005 08:22 AM
