Old 07-30-2009, 07:25 AM   #1
Profile:  1963 26' Overlander
Originally Posted by dieseleagle View Post
Then I tried running a putty knife all the way around and, lo and behold, just behind the wheelwell on the curb side a dimple on the skin was hung up on a split from forming the belly pan wrap. It was the barest hangnail, but as soon as I freed it the shell settled right in place where it belonged.
If that ain't it, then Aerowood is no doubt right.
AWESOME pictures dieseleagle!
Yes, just the barest bit of metal can hang up the entire works. When I was reinstalling the aft subfloor pieces, I briefly had a hard time getting the shell back in position, situated correctly in alignment with the original holes in the original j-channel. Then, recalling Frank's words on this very subject, I ran my putty knife around the entire perimeter one final time, and found just the smallest bit of a rivet still stuck in a hole in the channel. Didn't seem like it would cause any problem at all, but once removed, everything settled in just fine.
Good luck!
Old 07-30-2009, 08:33 AM   #2
NorCal Bambi's Avatar
Profile:  1963 16' Bambi
Yreka , California
Images: 21
This is a good short section on how and why a shell alignment might have problems. Maybe an administrator can figure how to put this on the Forums list. With the title Shell realignment.
Don
NorCal Bambi is offline   Reply With Quote
Old 08-03-2009, 10:48 AM   #3
truckasaurus's Avatar
Profile:  1961 26' Overlander
Airdrie , Alberta
Images: 24
porcupine shot
We've had some serious weather this weekend so only about 6 hours work on the trailer so far. We prepped the old panel and made the new one and got it cleco'd in place. (giant hail 20 miles away!) We used a Fein Multimaster with the scraping blade to get the black stuff with mesh embedded in it off, awesome tool.
Today should see it Vulkum'd and riveted.
ID:	84866   Click image for larger version
preparing for the maiden voyage in 2010...
truckasaurus is offline   Reply With Quote
Old 08-03-2009, 11:09 AM   #4
Profile:  1963 24' Tradewind
Cape Coral , Florida
Great job! Its hard to keep such a large panel straight and smooth. Did just the two of you manage it?
dieseleagle is offline   Reply With Quote
Old 08-03-2009, 11:20 AM   #5
3Ms75Argosy's Avatar
Profile:  1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Wow truck, looks great! Did you cut the panel yourself, or did you end up having it cut to measure when it shipped?
Love the kitty watching too!
Marc
Old 08-03-2009, 11:26 AM   #6
Airdrie , Alberta
Images: 24
Thanks guys. Just me and the GF, it would be easier with three people but was perfectly doable with two. I had three pieces shipped, one 32' 032", one 16' 032" and one 16' 040".
Old 08-03-2009, 05:44 PM   #7
Kevin245's Avatar
Profile:  1976 31' Sovereign
Rock Hill , South Carolina
Looking Good Truck.....
Experience isn't always the best way to learn...You usually get the lesson first...And the instruction afterwards...
Kevin245 is online now   Reply With Quote
Old 08-04-2009, 07:47 AM   #8
Yreka , California
Images: 21
Most impressive!
Old 08-05-2009, 07:42 PM   #9
Airdrie , Alberta
Images: 24
Curbside
Whilst I wait for some longer rivets to arrive and get my hands on wheel well trim I thought I'd press on. (I still haven't found good J trim, the Brunnerent stuff seems OK but the shipping is shocking; also it's occurred to me that my curbside is 0.032" plus 0.040" so I may want 3/32" not 1/16" trim especially as I'm sure the Vulkem between the two takes up some space).
Today I finished glassing over the unwanted holes in the fiberglass end caps and finished off with a few skim coats or Bondo all nicely sanded smooth.
Lastly I removed the lower door hinge and the whole door assembly to get at the side panel better. The 12' curbside is now just hanging on Clekos ready for removal, clean up and templating onto 0.040". Most of the stringers are OK, I'll replace two that took a beating at some point in the past.
I know it's probably not the best time but I'm sorely tempted to pick up either the Makita 9227C or a Dewalt variable speed 7" polisher, a couple of soft 8" buffs and some 3M marine aluminum polish just to see how the old material will clean up..... I figure with the project sitting out all winter if it's a bit shiny it'll keep my motivation up.
Old 08-06-2009, 09:03 AM   #10
Yreka , California
Images: 21
Chance for a good discussion
CanoeStream has sent me a PM asking what I meant in my comment about there being great stuff in this thread. All those who have added ideas to this thread have good and varied ideas. Here is a change for another one of those great discussions. That beautiful sheet of aluminum being kept in place with all those clecos looks beautiful. However the looks can change a lot when the rivets start falling into place. If you have ever watched a person who has placed a million rivets, it looks so easy and the results are amazing. For the first timer, it can be a disaster. Rivet gun hop, great dimples in the sheet around each rivet location, loose rivets that leak, on and on. Then there is the whole discussion about what the back of the rivet should look like is it has been bucked properly. If you are a experienced aircraft mechanic this may be boring, but to the new-be it can be great knowledge. Are all of you willing to jump in with bits of rivet knowledge?
Don's ramblings.
Old 08-06-2009, 09:11 AM   #11
Sure, I'm certainly interested in hearing from those who are more experienced than I am!
Here is what I will add-- it is absolutely imperative that the riveter and the bucker stay in constant communication with each other, and do things consistently each time.
For example, if you are always counting to three and THEN pulling the trigger, don't ever pull the trigger ahead of that beat. Also, if you are consistently firing one burst of riveting, don't hit it with a second burst when your bucker isn't expecting it. Communicate with your bucker and count it out again. If you DON'T do these things, then there is a chance that your bucker will pull the bucking bar back, or not apply proper pressure. This can lead to unsightly results at best (large indentations in the skin around the rivet), and at worst, you can end up firing a rivet all the way through the skin and blasting a huge hole (fortunately this did not happen to me, I did this on a scrap of test aluminum to see what would happen. Wasn't pretty).
It seems easy, but even after doing over a hundred perfect rivets, I miscommunicated one time and dimpled my skin pretty severely. Oh well, live and learn.
Old 08-06-2009, 10:04 AM   #12
Airdrie , Alberta
Images: 24
Great idea Don. It can be like looking up a project in a Home Depot manual where everything looks square and plumb and then comparing it with the aftermath of a DIY disaster where every piece of lumber seems cupped and twisted. Luckily for me Airstream must have been in a budget crunch and unable to afford a piece of string to set the rivet lines straight so I know no matter how good a job I do it will still look more artisan than craftsmanlike.
At the introduction session for the A&P course I start next month the instructor showed me the sample rivets they get students to do at the start so that at the end they can see how much better they are. They looked just fine to me so I'm aware that no matter how well I do on this trailer next year I'll see every defect.
So far I'd say communication is the most important factor; like Marcus says if riveter and bucker aren't in sync it's going to end badly, (for the trailer and the combatants). We did a practice run on a mock up section of C channel and set the regulator on the gun which seems to help. Next I think it's harder to mess up when the substrate being riveted is more solid/ secure so I try and start the session off on a window frame, rib/ bow or something that isn't going to flap about. With the panel totally Clekod down I don't think it makes much difference but I've been starting in a central area and working out.
I doubt I'm doing it the correct way but once my bucker says go I'm "brapping" in a few pulses so that my bucker can call stop whilst I can hear her in between the cacophony. I'm getting a feel for the rivet squishing up now which makes timing the duration of the rivet action better.
I'd like some tips on getting Vulkem off the clekos! I have them soaking in mineral spirits and next I'm going to try WD40 but there must be a better way.
It would also seem logical for the riveter and bucker to swap roles occasionally, kind of like a 360 appraisal; I haven't tried this yet but hope to on a smaller panel.
Old 08-06-2009, 10:17 AM   #13
thinking outside the box
Commercial Vendor
62overlander's Avatar
Profile:  1962 26' Overlander
1954 22' Safari
1954 22' Safari
Catonsville , Maryland
WD40 takes it right off. Buy it by the gallon....
62overlander is online now   Reply With Quote
Old 08-06-2009, 11:21 AM   #14
Airdrie , Alberta
Images: 24
A gallon it is then, thanks Frank, also I'm resisting the urge to get the polisher ASAP and instead ordered the Jestco kit. I spoke with a guy at 3M earlier and he was very helpful but their 8" pads (#05703) are about $40 and up so I could see it getting really expensive fast.
factory new shell? finalcutjoe 2007 Classic (all lengths) 17 05-16-2007 02:21 PM
How big a shell off has been done? tbrom Repairing/Replacing Floor &/or Frame 1 10-12-2006 10:45 AM
Shell on or off??? Bradjun1 Repairing/Replacing Floor &/or Frame 3 09-20-2006 12:19 AM
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 06:46 PM
Replacing the shell ?? William8979 Repairing/Replacing Floor &/or Frame 2 05-11-2005 09:22 AM
