Old 10-16-2011, 06:35 AM   #1
1967 22' Safari
Stevens , Pennsylvania
Shell Off Question
I'm about to separate the shell from the frame on my 67 Safari. I intend to brace the interior with 2x3s, lift the shell and remove frame out from under. My question is; Does anyone know approx. how much a 67 Safari shell weighs? Is this something 4 men can do by hand, or is it best to use 4 bottle jacks from the inside?
Evets is offline   Reply With Quote
Old 10-16-2011, 06:50 AM   #2
x
XXXX , XXXX
use bottle jacks for more control and stability
wasagachris is offline   Reply With Quote
Old 10-16-2011, 08:11 AM   #3
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Think worst case scenarios...
- The shell will want to turn turtle, flip up side down if anyone gets the giggles (just kidding almost yet if the worst should happen..)
- 1x3's are not enough to lift shell using a bottle jack as they will give that 3" up in deflection at the center (I've seen that) when jacking from a foot in from shell with bottle jacks on both sides
- without the jacks there will need to be another one or two men to chase down binding areas to keep from damaging things, the rear tie-down plate was caulk & corrosion welded on mine and the front & rear plates both had hidden rivet slivers that bound up the lift.
-2x3s made a good sleeper to tie into the shell at multiple ribs to spread the weight when the shell is set back down on the cross-supports, like the mud/sleeper plate that rests on a houses concrete foundation that all the following framing attaches to.
- Once you get the shell braced, lifted and resting on blocks above the trailer floor you might try a man-powered lift but then there is no stopping, turning back or setting it down for a minute until its exactly where it needs to be over the cradle you've pre-built for it, unless its directly above the frame not walked away to a remote 'dry-dock' area..
Old 10-16-2011, 09:06 AM   #4
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I seem to remember an advertising picture back in the early 70's of several people holding up the shell of an Airstream which would imply the weight is not much but don't recall if it was less inner skin and windows
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 10-16-2011, 11:46 AM   #5
Wabbiteer's Avatar
1972 29' Ambassador
Minus all liners, insulation, window glass, wiring, hatches, vents & fans, A/C and various covers on the roof it'd sure be easier...
...and an EDIT on above post - should read 2x3's are not enough to lift shell...
Old 10-17-2011, 06:04 AM   #6
1967 22' Safari
Thanks for the replies. I appreciate your input.
The 2x3s are just for interior bracing. For lifting I'm planning on 2x6 or double 2x4s.
The trailer is almost completely gutted at this point. Interior skin, wiring and all. The only thing still there is the two fiberglass end pieces and the windows.
For the sake of safety and the aforementioned "worst case scenario", I suspect I'll probably go with jacks. That means I'll have to build a stand for each corner. The plan is to raise the shell and move the frame out from under, then set the shell down right where it is.
Man, I wish I could do this in a shop with a nice overhead hoist. Oh well........
Old 10-20-2011, 06:31 PM   #7
Tool Hoarder
West , California
Before you lift make sure to take accurate measurements of the interior length. Also make sure to take note of where the ribs bolt to the outriggers. I am having an issue I need to move my shell back 1/2 " on my frame and it doesn't want to.
marzboy is offline   Reply With Quote
Old 10-21-2011, 06:51 AM   #8
1967 22' Safari
Good advice. Thanks. I hope you get your problem figured out.
Old 10-29-2011, 07:36 AM   #9
1967 22' Safari
Ok, separation is complete! A little nerve wracking but everything went smoothly. We used a floor jack to get enough elevation to get screwed together 2x4s underneath and up on block towers. I added some extra bracing and it seems quite stable. Waiting on the new axle and doing the needed frame mods now. Hopefully, we'll have the frame back underneath within a month.
1970 Shell Off Questions P&K Repairing/Replacing Floor &/or Frame 1 07-22-2011 07:22 PM
Steel / Aluminum wheel question polarlyse Wheels, Hubs & Bearings 12 05-29-2011 07:49 PM
Shell removal confusion P&K Repairing/Replacing Floor &/or Frame 6 05-21-2011 06:32 PM
Blasphemous question woytovich General Repair Forum 15 04-09-2011 08:36 AM
Shell off or on? Breadbug Repairing/Replacing Floor &/or Frame 3 02-06-2011 11:06 AM
