Old 01-03-2012, 06:26 PM   #1
1979 28' Ambassador
Saint Amant , Louisiana
Shell off floor pattern - rear corners different!
I started a shell off restoration a couple weeks ago on a 1979 28'. It was the first Airstream my grandfather ever sold when he started working as th GM at the now gone AS dealer in New Orleans.
Anyway, i have the shell off and before i pulled the floor and started my metal repair i used the old floor to pattern new pressure treated plywood. Since there was some plywood rotted away i used the best corner on the front to to help fill in a gap in the radius on the other side. Both front corners proved to be identical. When i got to the back i started with the best corner and cut it. When i took the drop and placed it on the other side to fill in the missing radius i dicovered it was drastically different. The street side rear corner had a smaller radius or was pulled in a good 1.5 inches. All the steel, aluminum, and plywood are all original so it appears to have left the factory this way.
I would guess all plywood is cut from a jig at the plant. It seems very strange that the two rear corners were cut so different. I was curious if anyone had ever run across this. I would imagine many may pattern and never compare but was wondering if anyone else had seen the same thing.
Replacing rusted out steel now and to the sandblaster hext week!
Kieffer
Kieffer4 is offline   Reply With Quote
Old 01-03-2012, 06:45 PM   #2
1968 22' Safari
San Antonio , Texas
Please do a search on the use of pressure treated plywood and it's interaction with aluminum.
Map_man is offline   Reply With Quote
Old 01-03-2012, 06:49 PM   #3
touched
62overlander's Avatar
1948 22' Liner
Catonsville , Maryland
you would never use PT wood inside your house would you? PT plywood is very unstable, not flat, full of voids, and varies drastically in thickness over the sheet. The way it reacts with aluminum is just one of many reasons why not to use it.
Frank Yensan The Airstreamer's Club USA-1 "we're dead serious about having fun"
http://annalumanum.blogspot.com/http://frankstrailerworksblog.blogspot.com/
www.frankstrailerworks.com
62overlander is offline   Reply With Quote
Old 01-03-2012, 06:53 PM   #4
moderator
Brandon , Mississippi
wow, that is odd. I can comment that my '91 is consistant from side to side. I'm pretty sure my '63 was, based on the small shards of flooring that was left.
I know the '63 is the same now, that's how I 'cut the corners'...
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-06-2012, 02:16 PM   #5
InsideOut's Avatar
1956 22' Safari
Edgewater , Colorado
Images: 94
I can tell you neither our (at the time) '64 GlobeTrotter or our '56 Safari were consistant side-to-side or front-to-back at the curves.
I concur...don't use pressure treated plywood in your trailer. We used marine grade, it's much more stable, flat, consistant and it doesn't off-gas or interact with the aluminum.
Shari
RMVAC | WBCCI DenCO Unit | Tin Can Tourists | Sisters on the Fly | BIRDY - our '56 Safari
Old 01-06-2012, 02:42 PM   #6
Tool Hoarder
marzboy's Avatar
1965 30' Sovereign
West Hills , California
Go with MGP you will love it! Frank (62overlander) recomended Aquatec and it really worked well for me.
Behind every great man, there is a woman rolling her eyes.
My Airstream renovation and camping Blog
My frame and floor restoration thread
marzboy is offline   Reply With Quote
Old 01-06-2012, 05:55 PM   #7
Images: 59
The floor on our '59 was in good enough shape to measure. No two corners were the same radius. And some of them weren't even circular.
How does my rear end look? desertair27 Repairing/Replacing Floor &/or Frame 33 01-28-2012 09:02 PM
Rear End Sag on 2005 28' CCD tyggeln Repairing/Replacing Floor &/or Frame 6 11-01-2011 10:40 PM
Rear End Separation Permanent Fix? dmand001 Repairing/Replacing Floor &/or Frame 6 09-22-2011 04:46 PM
Rear window leak fixed! Really? I think so. GlobeTrottin 1964 Globetrotter 0 04-30-2011 05:42 AM
