Old 06-20-2015, 07:59 PM   #1
2Rhinos's Avatar
1974 27' Overlander
1970 27' Overlander
Houston , Texas
Images: 18
Shell off Finally!
It's been a long process, but I finally made the commitment to finish this project that started way too long ago.
ID:	241186   Click image for larger version
Name:	Frame out 1.jpg
Name:	Frame out 2.jpg
ID:	241188   Click image for larger version
2Rhinos is offline   Reply With Quote
Old 06-20-2015, 10:08 PM   #2
1979 23' Safari
Wayland , New York
OMG you didn't! Just kidding I remember that point. Looks like you've got an awesome place to work on her as well.
Looks like you kept the wood to use as templates, very good! I had to estimate some of the curves since there was a bunch in the back rotten out.
A few lessons learned.
Replace the plywood with something that has at least one A face placed up so you'll have a nice smooth floor.
You can paint the entire top of the floor with porch&floor paint. Leave the underside unpainted so moisture has a way to escape if it does get wet.
Assuming you're not going to insulate the belly with fiberglass, don't do it. The fiberglass originally got sandwiched between the floor and metal framing, easy to install that way, but it also helped prevent floor squeak. Place a bead of polyurethane sealant/adhesive on top of the frame/outriggers then lower the new floor directly down onto it when reinstalling.
The very front and rear pieces of plywood have the U channel that just sits on top vs the C channel that wraps the edges of the wood. On those sections I tightly wrapped the entire edge and in from the edge about 1.5" in several layers of aluminum metal tape. To protect the edges from water/moisture.
For bolts when the time comes, consider grade 8, steel cap screws(bolts) nuts and washers, that have armor coating on them. They are VERY corrosion resistant, so shouldn't rust away for the next 30+ years. Plus not bad priced online at McMaster Carr.
Best wishes for a smooth project.
Old 06-21-2015, 06:56 PM   #3
2Rhinos's Avatar
1974 27' Overlander
1970 27' Overlander
Houston , Texas
Images: 18
More progressClick image for larger version
Name:	ImageUploadedByAirstream Forums1434934469.306724.jpg
ID:	241268Click image for larger version
Name:	ImageUploadedByAirstream Forums1434934548.511001.jpg
ID:	241269Click image for larger version
Name:	ImageUploadedByAirstream Forums1434934574.927347.jpg
Old 06-21-2015, 07:05 PM   #4
2Rhinos's Avatar
1974 27' Overlander
1970 27' Overlander
Houston , Texas
Images: 18
And more photos Click image for larger version
Name:	ImageUploadedByAirstream Forums1434935006.678454.jpg
ID:	241271Click image for larger version
Name:	ImageUploadedByAirstream Forums1434935033.030401.jpg
ID:	241272Click image for larger version
Name:	ImageUploadedByAirstream Forums1434935060.582909.jpg
ID:	241273Click image for larger version
Name:	ImageUploadedByAirstream Forums1434935086.833483.jpg
ID:	241274Click image for larger version
Name:	ImageUploadedByAirstream Forums1434935114.218700.jpg
Old 06-21-2015, 08:01 PM   #5
1966 24' Tradewind
Kansas City , Missouri
Shell off yesterday, too ....
See mine at http://www.airforums.com/forums/f116...nd-135579.html
We seem to have similar work environments. Any reason you used gantries as opposed to the overhead beams?
Slats is offline   Reply With Quote
Shell on? Shell off? painterfam Repairing/Replacing Floor &/or Frame 11 05-30-2015 03:44 PM
Shell on shell off? Newbie Dustycowgirl Repairing/Replacing Floor &/or Frame 28 03-12-2015 12:12 PM
Finally some pics of my shell off P&K Repairing/Replacing Floor &/or Frame 52 01-06-2012 04:30 PM
Shell on? Shell off? Althea68 Repairing/Replacing Floor &/or Frame 55 04-01-2011 09:35 PM
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 05:46 PM
