Old 10-06-2014, 06:40 PM   #1
2008 16' Bambi
Redwood Valley , California
Shell off 2008 Bambi!
Hey, I have read many of the posts about removing the shell, as I am replacing the floor. I have all the interior removed except for the ceiling panels, bolts and screws removed from around the "C" channel, just starting to remove the lower section of rivets from the exterior. The C channel wraps around the plywood top and bottom so do I remove the rivets from the bottom areas of the ribs (that are laying in the C channel) and then it should separate right!
My question is I am lifting by way of jacking it up from the floor. Other than the bracing for lifting, does the body need additional bracing. I saw a picture on a forum of lifting from the ceiling and the rest of the body had no other bracing. Any info would be great.
RV Daddy.
RV Daddy is offline   Reply With Quote
Old 10-06-2014, 07:04 PM   #2
1981 31' Excella II
New Market , Alabama
As long as the ribs are intact the shell should hold its shape. Hard to believe a trailer than new needing a shell off. You may have the newest trailer with a shell off.
Perry
Old 10-06-2014, 07:17 PM   #3
reinergirl's Avatar
Hollis , New Hampshire
Jacking from the bottom creates different stresses than lifting from the top.
Honestly I think bracing it would be a good prudent measure. Make sure you also brace it accross the door threshold as it will want to spread. And if you have it outside make sure you tie it down well to the ground. .
reinergirl is offline   Reply With Quote
Old 10-06-2014, 08:02 PM   #4
2008 16' Bambi
Perry
Hey Perry, yeah it had a broken window in the rear and the PO let water get in it, so it buckled the floor. Also it was leaking around the water tank in the front as well. I'm bringing it back to fresh, so it has to come off!
Old 10-06-2014, 08:08 PM   #5
2008 16' Bambi
Its in my shop and out of the weather. It's a tad over 12' ID front to rear so I thought a few cross members and one down the center a foot off the floor. Are you talking about bracing if the entry door is removed, or?
Thanks for the reply,
Old 10-11-2014, 07:43 AM   #6
2008 16' Bambi
2008 Shell Bambi
Well I got the shell off yesterday. I do believe next time I will build the gantry setup, as lifting it was a royal pain....
Thanks for all the advice!
Camper Shell or No Camper Shell for Pickup TV KJRitchie Tow Vehicles 28 03-14-2017 07:23 AM
Shell on shell off? Newbie Dustycowgirl Repairing/Replacing Floor &/or Frame 28 03-12-2015 12:12 PM
HELP! Can I fix sagging Outriggers with shell on? Or just pull the shell? Mixter Repairing/Replacing Floor &/or Frame 3 01-24-2013 11:59 AM
Shell on? Shell off? Althea68 Repairing/Replacing Floor &/or Frame 55 04-01-2011 09:35 PM
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 05:46 PM
