Old 11-27-2010, 08:56 PM   #41
Airstream Fanatic
ND10CentCan's Avatar
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Bismarck , North Dakota
We have a big, fat maybe
Tomorrow a husband of a friend of my daughter's is going to come and take a look at the Tross. It will be the first person outside of us to gaze upon it's sorry state of frame decline. Now to see if he actually shows up and decides not to run at first glance. Story to continue....might be the fastest departure on record. If we can just get him to stay long enough to utter some sort of direction....besides run for your lives.... we will feel grateful.
ND10CentCan is offline   Reply With Quote
Old 11-27-2010, 09:27 PM   #42
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
WoW, this is getting interesting!
ArtStream is offline   Reply With Quote
Old 11-28-2010, 07:06 AM   #43
Images: 59
When welding on the frame, it's reel important to choose the right rod, and make sure you hook the gounding line to a good sinker location.
If it isn't on a solid perch on bass metal, you'll have a crappie weld.
Old 11-28-2010, 08:14 AM   #44
I wouldn't have believed that this thread cod get batter, but it has!
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 11-28-2010, 09:32 AM   #45
Images: 59
This thread is floundering.
Old 11-28-2010, 10:54 AM   #46
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Salmon should tell you all to get back on track!
Sorry!
Marc
Old 11-28-2010, 12:09 PM   #47
Splitrock's Avatar
Sioux Falls , South Dakota
Hi Sandy
I thought about the topic of welding and I wondered if the set up was all done with parts cut, connecting points ground and clean, plates and gussets pre-made with some extra material on the job, why the actual welding would even take half a day. When I set up a job, I tack it as I go, then when everything's as I need it, I come back and make my welds.
If I have to section a frame, I'd template it, and weld it up in a jig. There'll never be a better time to replace the axles and maybe install new tanks than now. With the axles off, tanks off, and frame down on a flat slab, the set up and jigging will be simpler. Now if I have a tractor and loader or a forklift, I can stand the frame to make my back welds:-)
If you can't buy the steel, do the cutting, make the setups, fix the jigging, and grind everything, then it's probably not a do it yourself job because you'll never get to welding without all the pre-work. I have the best metal working shop in the world one mile from my home. If I had to rebuild a frame, I'd just take it to them with a blueprint and sit at home in my chair. It might take guys like that three months to get around to my job because they're busy. That still wouldn't be a problem for me.
Years ago I had a friend in West Fargo with a manufacturing plant that made farm equipment. There were shops all around him at West Fargo. I've visited Bismarck but I didn't visit any plants while I was there. There must be shops there. It seems rather foolish to learn and equip a whole trade just for one trailer frame repair unless the fun factor is there big time.
In perspective . . . taking the body off a pretty big Airstream trailer is a big project . . . and you've that done. (I hope you plan on making floor templates before removing the old wood floor.)
I wonder if a blueprint of your frame is available from Airstream. I just fear those frames were jig welded to fit up pre-made stamped steel parts. It's gonna seem pretty important for those outriggers to line up perfectly with your body ribs.
Gary
Old 11-28-2010, 02:27 PM   #48
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
Lining up the outriggers is vital to the correct loading of the frame and shell. Working from a template (the old frame) is good, but it's always wise to have a backup.
I would choose a starting point, line the rear end of each frame rail, and measure each outrigger and crossmember (left and right) on the left rail, then each crossmember and outrigger on the right rail, as a distance from the back edge. Then, I'd measure the A frame angles, and measure the outrigger/crossmembers from them. From this, I could reconstruct the frame if a calamity befell the original. It's also important to locate the axle mount points correctly. This is a most critical measurement as it strongly affects ease and stability of alignment when you add your axles.
One of my most valuable assets when I owned my workshop back in the 90s was a completely flat and level floor - truly flat concrete floors are surprisingly hard to find - I had to have this one skimmed with a very runny self-levelling mix to get it right.
TX-16
Dave Park is offline   Reply With Quote
Old 11-28-2010, 07:10 PM   #49
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Glory, Glory Be!!
I think the skies have parted and the sun has started to shine on the Tross. Or at least on me! The husband of the friend of my daughter's showed up at the appointed time and took a couple of hours looking over and discussing the situation with the man in charge. Jake works at a welding shop in town and has agreed to do the deed!! He will work on his own on the weekends and we are so happy
I told my husband that if he showed up, he should block the driveway and flatten his tires if he tries to get away. Luckily Jake wasn't deterred; he actually thought it would be fun (?)!! He is a youngster and so probably doesn't really know how deep he is into it. He told us that his shop would consider our project "small potatoes" and wouldn't do it. Now to actually get the project underway......I am happy, happy, happy. This seems like such an accomplishment to have found someone to fix our frame! To think that finding a welder would bring me to tears!!
Now the next challenge is to decide on the new axles. Husband says the new frame is going to be "beefed up" and so needs suggestions on what type to order. Anyone with ideas on a steroid based AS frame for a 31' 1976 AS Sovereign rear bath, feel free to chime in. The more info, the better!
Hopefully all goes well and Jake can do the work without too much trouble. The big deal is to make it just as it needs to be with all the proper angles and such. He seems to know what he is doing and I hope this just isn't too good to be true. We have some time over winter before we will be putting the shell back down on the frame. Speed isn't as important as accuracy! Time will tell but so far, I am happy, happy, and more happy.
Sandy
Old 11-28-2010, 07:28 PM   #50
x
XXXX , XXXX
Sandy I so happy for you. BTW thanks for the thanks.
Are you going with a whole new frame.
If yourè going to beef it up use thicker steel with larger flanges for more strength and wider attachment area for the floor and belly pan. You could also box in the frame for more strength.
Consider the 4500 lb axles due to more frame weight and any interior added weight from renos. Your trailer is now about 5800 lbs add the weight for the frame and interior and that should leave you plenty of room for cargo and water weight.
My freind built my frame right on top of the old one using it as a template. He built main rails and crossmembers plus axle plates upside down and once it was ready we flipped it over to weld on outriggers. That way main rails lay flat on the old ones and the axle plate was not in the way during initial set up.
Can you put up a temporary structure around the frame to shelter it from wind and snow during the build. Wind really messes up mig welding and so does moisture from rain and snow.
wasagachris is offline   Reply With Quote
Old 11-28-2010, 07:44 PM   #51
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
More glory to add....
Thanks for your continued info and support!
Jake says he is going to basically have to build it from the ground up due to the level of decomp on the frame. I am not sure decomp is the right term but that is what it looks like to me. Something died....anywho, if he puts all new metal in we can be sure it will be good for a long time to come.
He works in a shop in town so he thinks once he clears it with the boss, he can work on it during the weekends and get it done indoors. That makes the prairie winds not such a problem. I am guessing with the walls on his shop, the MPH wind in ND should be about 35 as he welds.
The Albatross has a rookery going up but our trusses were three weeks late and winter has arrived here on the plains. Husband is working as frantically as he can to get everything done as quickly as possible. Once the roof is on the building and the frame is repaired, it is game on. I can hardly wait. I have the interior paint, the curtain and upholstery fabric all ready to go; Yippee!! It feels like we won the lottery when we found a welder!!
Old 11-28-2010, 08:01 PM   #52
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Thanks Gary
Originally Posted by Splitrock View Post
Hi Sandy
Gary
Not only did we find a welder (after three months of looking) but we hope to have it done before spring!! I hope he doesn't change his mind on the project once he gets home and thinks it over His wife was happy for him to take the project on as they are young and as most young couples, in need of additional sources of income.
The man in charge has the manuals for the AS and has tried to calculate out all the different angles on how to do things as efficiently and effectively as possible. Blame that on the engineer in him! He also is stressing to Jake how important it is to have things not only accurate but completely accurate. I would hate to think of us traveling along and seeing the AS tumble off the road. Someone would have to hold me back from climbing into the ravine after it!! Good thing ND has so few ravines
Husband is still going to take the welding class come January anyway. Welding seems like such a useful skill that we both want to take the class. I can't take another class on top of my other classes so he wins this time. The instructor is a long time vo tech instructor that has a good reputation. I can't wait to see what he learns and we can learn for that "fun" factor. Others may have a hard time understanding why this stuff is "fun" but I love it.
I fear I may already have the AS fever and have no viable cure in sight. I see a number of people with three and four AS to their credit on the AS Forums and we have a little over 3 acres out here. How many can we legally put out here before the neighbors start to complain?
Sandy
Old 11-28-2010, 08:16 PM   #53
Splitrock's Avatar
Sandy
Hi Sandy
My son asked me yesterday if I'd have the energy left to take any trips by the time I get my trailer completed. Energy won't be the issue . . . I'll be broke!
Gary
Old 11-28-2010, 08:26 PM   #54
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
We can identify....
Hi Sandy
Gary
We can already identify!! Once we got into the entire project and realized we paid way, way too much for the AS to begin with, it was too late. The guy who sold it to us wasn't necessarily at fault; I think until you start looking around and peeling things back, you don't know. So I won't blame him. Shoot, now if we were to look at one, we would be a lot wiser than we were a few months ago.
We have been waiting for our youngest to finish college (he's on year 5 now....) in order to have the man in charge be able to retire. Now we say "When we get the Albatross completely renovated and the kid out of college..." Looks like I could be working for another twenty years Greet the man in charge when you see him traveling the byways while I am still working the salt mines
Old 11-28-2010, 08:29 PM   #55
Splitrock's Avatar
He was smart to marry a younger woman:-)
Old 11-28-2010, 09:41 PM   #56
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Little did I know he had a plan a long time ago
Here I thought it was because of my winning personality; now I find out because he figured with the age difference between us, I could work another ten years and support his construction habits. Sly devil
Old 01-07-2011, 04:56 PM   #57
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
A welding we shall go, a welding we shall go
The man in charge officiallly signed up to begin his welding course in the next few weeks at the local vo tech class offered to community members. It is 48 hours of in class time spread out over the next three months. I visited with the instructor (I work in the same building now) and said "If he misbehaves, I don't want to hear about it." He will do well and we are anxious to be able to do the welding part ourselves and have a clue about that whole process.
The instructor said typically after people take the introductory course, they want to have more time for practice and will either take the class again or ask for the advanced class. He also said most people end up buying a lot of welding equipment because they like it so much. I started to sweat at that point. How much welding equipment are we talking here? The newest adventure begins.....
Old 01-07-2011, 06:47 PM   #58
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I fully agree with the instructer, it's almost as addicting as aluminum.
Old 01-07-2011, 08:53 PM   #59
Images: 59
The welding equipment is not big deal. Probably less than $1000.
The problem is all the auxullary equipment. Start with clothing. Gloves, jacket, helmet, cap, sleeves, goggles. Then you need lots of clamps. Then a nice oxy torch for cutting, and a band saw, and grinders, and a sandblasting cabinet. And a nice welding table. And a plasma cutter. And a bigger shop with a fume exhaust.
Pretty soon you're talking about some real bucks.
Old 01-07-2011, 09:24 PM   #60
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Uffda
Uffda...that is Norwegian for many things such as I can't believe it, or I can't deal with this, or What should we do, etc. Uffda, uffda....I have fears of more equipment headed my way. The project that began with a first time ever adventure on Ebay turns into another story. One of the people at work asked if we were keeping track of the money we have put into our Airstream "project" and the response is yes but kind of no. If we truly looked it all over, it woudn't make a lot of sense to most people.
On the other hand, if we look at how much we have learned and discovered, we would say it has been an education and education doesn't come cheap. We have enjoyed trying to figure things out and looking up info on the Air Forums. We have discovered a number of people on the forums that think like we do, have quality in mind, and don't mind taking their time to do it right. It has been a new avenue that we didn't even have to discover before.
So the welding adventure begins and I have asked that my husband teach me when he knows what he is doing. He has taught me so much from just being his "assistant' in the shop that I can tell what the next step is going to be before he says anything when we work together on a project. It has allowed me to feel more confident in the shop and to know I can learn this stuff. It helps immensely that I like this kind of work and want to learn what I don't know. That amounts to a whole lot...the parts I don't know segment.
So, another chapter begins in the Albatross story. We are pushing snow out of the rookery every day and trying to work when there is daylight available. Our son was home over Christmas from college and helped a lot getting the trusses up. The sheathing has started to go up on the roof and we hope to get that done by the end of the weekend. I am hoping for less snow and no wind! Uffda, uffda.
frame, repair
Help in fixing leaks during frame up restore badelson Leaks - Weatherstrips, Gaskets, Caulks & Sealants 11 08-04-2009 10:22 PM
Big Job turned into bigger JOB, need advice. lebolewis Waste Systems, Tanks & Totes 10 11-16-2006 06:28 AM
Hello - DYI network info? higgy116 Member Introductions 5 04-06-2006 01:37 PM
Take this job and shove..... zduke4x Off Topic Forum 9 10-11-2003 08:02 PM
