Old 08-21-2011, 07:14 PM   #141
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Originally Posted by ND10CentCan View Post
a naughty decal on the back window.
Got pics of the sticker, could have been a collectors item and worth millions. Just saying........ you never know....... I'm not into that sorta stuff but I know a friend of a friend who has this cousin on his step mothers side with a roomate who has a son who might be.....
OK - moving on now.......
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 08-21-2011, 07:23 PM   #142
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Sandy,
Since you have all new metal, I'd recommend an automotive epoxy primer and a good top coat like Eastwood Ultra Chassis Black or some other type of automotive frame top coat. Maybe a POR-15 product. Lots of options with new metal. It is important to make sure the new metal is cleaned and degreased before priming.
Lance
Top is offline   Reply With Quote
Old 08-21-2011, 09:03 PM   #143
Airstream Fanatic
ND10CentCan's Avatar
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Bismarck , North Dakota
Source?
Originally Posted by Top View Post
Sandy,
Thanks Top,
Do you find the paint online or do you find it locally? I know I will be painting it so I want to get enough to do two coats on it all. I would want it to be applied by a brush and not a sprayer. I don't work quickly but I do it well...or as best I can anyway.
Does the color matter or can we go with plain old black? Color coordinate with the black on the axles? Do you have to use the same line of products for the primer and the top coat or can you interchange them?
As you can see, I need lots of help to steer me in the right direction.
Sandy
ND10CentCan is offline   Reply With Quote
Old 08-21-2011, 09:13 PM   #144
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Just my luck
Shoot and I just used a razor to scrape it off the bathroom window too. Just my luck it was worth millions and I threw it away. I still have all the broken plastic letters that spell MICHIGAN though if anyone is interested. Also have "10 Cent deposit on this can" in blue vinyl repaired in places with black electrician's tape if anyone wants to piece it back together. Good news is that the deposit statement was on both sides of the trailer so double the fun there.
Half of the US is available now too except I am still stuck with Louisiana at this point until I can get it completely off. Stubborn little state that it is. I did notice that the only states the trailer didn't make it to was Oregon, Washington, and Alaska. I think I should throw in Hawaii as a safe bet too.
Sandy
Old 08-21-2011, 10:20 PM   #145
clancy_boy's Avatar
Kiln , Mississippi
Images: 8
Hard to wash off Louisiana, been trying for years..... The stink is horrible.
Old 08-22-2011, 09:29 PM   #146
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Tonight my husband's welding instructor came out to help and advise him on some big questions like the hitch. He did say DOT would want someone certified to put the hitch on but as long as you use the correct welding method, the right materials, and follow the welding process, you won't have problems. So here we go on that.
He has been a big help to us and he doesn't want anything for his time. I am wondering what to get him that he might like such as a gift card to a local restaurant or to another store he might utilize such as Menards or something. He is a generous person to come and crawl around the floor and show my husband different approaches to welding.
Made the critical mistake of going and visting with Barry over this and that, and I took up too much time. Dearest husband gave me the neck slashing sign and I got the message so I skeddadled out of there. I am not sure if the door to the Rookery will now be locked or not.
signed: SA in the doghouse at least for tonight
Old 08-22-2011, 10:06 PM   #147
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Every welder needs one of these ... less than 100$ good gift
http://weldingsupply.securesites.com...S2-80||1|206||
Darkspeed is offline   Reply With Quote
Old 08-23-2011, 05:33 PM   #148
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Good idea!
Weldingsupply.com / StrongHand / MS2-80
Thanks for the tip. I am going to nonchalantly quiz him on what he really likes...just for starters. I am going to show these to my husband too and see if he thinks it is something Barry might like. Good idea!
Sandy
Old 08-23-2011, 05:38 PM   #149
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Sandy,
Because I am rather clueless about this process, can I use these products with a brush or do I have to invest in a sprayer? I would prefer to brush it on and avoid all the spraying if possible.
I have a coupon for some % off on Eastgate for today but it didn't say on the Chassis Black if I could use a brush and it didn't say I would need a primer. I think they might be assuming everyone knows what each one needs and application methods when that is certainly not true for me. Do you happen to know?
Sandy
Old 08-23-2011, 06:30 PM   #150
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Sandy,
You sure can brush on the Eastwood products. That is what I do with very good results.
Lance
Old 08-23-2011, 06:53 PM   #151
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
From the Eastwood extreme chassis black can:
Directions
1. Surface must be clean and dry before painting. Use Eastwood PRE painting prep to remove residual grease and oil. Can be used on bare metal or over primer. For increased durability, prime with Extreme Chassis Black primer quart (11194ZP), wait 15 minutes to one hour and topcoat with Extreme Chassis Black. Do not use over self-etching primers. Test for compatibility if not using over Extreme Chassis Black primer. For best results, use when can and room temperature are between 70-90F at 50% or less humidity.
2. Stir for at least one minute before use.
3. For spray-on application: several light coats give a better finish than one heavy coat. If desired, further thin with toluol or xylol. Apply only enough paint to achieve full hiding. For faster cure, apply a maximum of two coats of primer and two coats of Extreme chassis black. Allow 24 hours between coats.
4. Finished article should be allowed to dry 48-72 hours before being handled.
Lance
Old 08-23-2011, 06:55 PM   #152
Darkspeed's Avatar
1972 31' Sovereign
It is much better to brush on. If you have any surface rust / powdery residue it will disturb this into the paint when brushed. If sprayed the paint can float on this layer of contamination and peel off in sheets at a later date. Brush brush brush!
Old 08-23-2011, 07:45 PM   #153
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Good deal!
Sandy,
Thanks for that quick reply. Do I have to use a primer beforehand or can I just do the paint?
Sandy
Old 08-23-2011, 07:50 PM   #154
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Directions
Sandy,
It's your choice to use a primer or not. I always do.
Lance
frame, repair
Help in fixing leaks during frame up restore badelson Leaks - Weatherstrips, Gaskets, Caulks & Sealants 11 08-04-2009 09:22 PM
Big Job turned into bigger JOB, need advice. lebolewis Waste Systems, Tanks & Totes 10 11-16-2006 05:28 AM
Hello - DYI network info? higgy116 Member Introductions 5 04-06-2006 12:37 PM
Take this job and shove..... zduke4x Off Topic Forum 9 10-11-2003 07:02 PM
