Originally Posted by Hobo Bob
So is it possible to asses frame condition with the belly pan and floor intact?
I like the floor plan of the early 70s 23 footers with rear bath and have seen some very sweet restorations with stainless baths and such. I wonder if a 2006 23 footer would be more reliable? Prices are close.
Hi
You can poke at the part of the floor you can get at (soft = rotted). You can also play with a moisture meter. In some cases you will spot a problem. In others, the rot will be dry and / or out of the way when you check things.
Frame wise, same thing. You can look at the frame in various places where it pokes out. Based on what you can see, you can guess about the rest. If the rust is in only in the "wrong" place, you'll miss it.
Inspection will simply improve your odds. There is no 100% perfect check. It will steer you away from trailers that you are *sure* have problems. The trailers that are left after inspection sorts things out still *might* have issues. Plan your efforts (and finances) as if there will be (correctable) problems. If they don't pop up, keep the money in the bank and finish ahead of time.
