Old 05-20-2014, 12:56 AM   #1
Anchorage , Alaska
Sealing Exterior Shell to the Belly Wrap
I have done a shell off restoration of a 1963 Bambi. As part of the refurbishment of the frame/floor, I have replaced the belly wrap.
I am ready to set the shell back on the new frame/floor/belly wrap. Before I rerivet the skin, I want to reseal. I thought I researched the sealant, and got some TemPro 635 from Tremco. However as I look at the old belly material and the old U channel. It looks like the original manufacturing technic was to spray a black tar like material using a process similar to applying rino-lining. And the caulk was used to seal hatches and openings in the shell rather than sealing between the shell and belly wrap.
What is the material closest to the original sprayed in "black tar"?
Others that have done a shell-off, have you resealed with caulk or with a sprayed in coating?
Aktundra is offline   Reply With Quote
Old 05-20-2014, 05:14 AM   #2
r carl's Avatar
Lin , Ne
3M® 8881 - Undercoating | O'Reilly Auto Parts
Old 05-20-2014, 08:03 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I have been using truck bed liner...high quality.
Old 05-20-2014, 10:39 AM   #4
Anchorage , Alaska
Oh, and a related question.
Are there any reccomended solvents to remove the old black tar?
Belly skin and Banana Wrap Alloy perryg114 Belly Pans & Banana Wraps 16 03-03-2014 05:12 AM
'63 Ambassador belly wrap esmaytum Belly Pans & Banana Wraps 0 07-30-2011 08:27 PM
Bumper, Belly Pan and Banana Wrap Repair DKAir Exterior Restoration Forum 0 06-15-2011 05:51 PM
Belly Pan & Banana Wrap Removal IronGiant Belly Pans & Banana Wraps 2 06-06-2009 08:56 PM
Floor and Frame fixed, now I need some belly and wrap help heavye Belly Pans & Banana Wraps 3 02-23-2007 12:14 PM
