Old 07-28-2016, 08:44 PM   #1
1976 29' Ambassador
Atlanta , Georgia
Screwing of the subfloor
Apology in advance as I do not have a picture as I'm working on the AS at my friend's place...
My subfloor was secured to the frame by what looks like a self-tapping screw with a very large flat phillips head. About half of them were rusted out so I need to find more. I've been browsing and looks like most people had the subfloor secured with flat head elevator bolts. But since I'm not dropping the belly skin, that's not going to be an easy option for me. I've been searching for past half an hour or so trying to find the exact replacement but have had no luck so far. It looks almost exactly like the flat head elevator bolt except with the phillips head, and the tip is tapered to a blunt point so I'm guessing it's not self-tapping but self-threading into a pilot hole...
Any ideas on where I can find a replacement? Thanks!
Chae is offline   Reply With Quote
Old 07-28-2016, 08:48 PM   #2
1979 23' Safari
Wayland , New York
Out of doors mart is where I got mine.
http://odmrv.com/catalog/index.php?m...roducts_id=638
Pre drill slightly smaller hole and it goes pretty smoothly.
Old 07-28-2016, 09:18 PM   #3
Unka Jack's Avatar
Fonthill , Ontario
Vintage trailer supply also has them. Wonderful service, quick delivery.
Although it seem like I know what I'm doing, I'm just standing on the shoulders of giants who have done this before and kindly posted their journey.
Cheers,
Jack
73's VE3ZPW
Unka Jack is offline   Reply With Quote
Old 07-28-2016, 09:35 PM   #4
1979 23' Safari
Wayland , New York
The ones from VTS are different. The ones from OODM are exact match. I bought both when putting my new floor down. I used the ones from OODM, they had wider heads and I thought they held better in some trials on scrap.
Old 07-28-2016, 09:37 PM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Any trailer shop will have them....so will Home Depot, Lowes, or ACE. They are trailer floor screws....imagine that.
Old 07-29-2016, 11:52 AM   #6
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
They are trailer decking screws, the best ones come from a bolt store like fasteners.....and use a torks adapter...
Old 09-06-2016, 12:38 PM   #7
Kemblkr's Avatar
2003 22' International
South Bend , Indiana
You want to use wafer head 1 7/16" #3 Philips head self taping screws. You will not need to predrill going into the metal frame. These are size #14 or 1/4". Fastenal has them for cheap.
You need the 1/4" screws for strength and the wafer head will sink nicely into plywood or osb leaving a nice flat surface and a lot of grab!
Kemblkr is offline   Reply With Quote
Old 09-12-2016, 11:12 AM   #8
missy crissy's Avatar
1978 Argosy 27
1000 Islands , ontario
New question: do you use the original holes for the screws or do you drill new ones?
I'm just about ready to install the new subfloor and was wondering how to pre drill the wood to line up with the original holes. Drilling new holes would be a lot easier.
missy crissy is offline   Reply With Quote
Old 09-12-2016, 12:45 PM   #9
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
I drilled new holes. Dripped a little spar varnish into each drilled hole prior to placing a screw.
youngpeck is offline   Reply With Quote
Old 09-12-2016, 02:40 PM   #10
1979 23' Safari
Wayland , New York
Drilled new ones. To use the old ones you'd almost have to drill pilots from below. Even that would be difficult because the crossmember gets in the way of a drill going straight up. Spray a little galvanizing paint or rustoleum in the hole if you have any. Protects the newly exposed metal from rust. Although all the original ones in my '79 were still tight and holding well.
Old 09-12-2016, 05:01 PM   #11
1978 Argosy 27
Just what I thought. Good tips about spraying with Rustoleum before screwing the floor down.
Old 09-12-2016, 05:22 PM   #12
Wabbiteer's Avatar
Jupiter , Florida
I see other types of screws being mentioned but here's what worked well for me...
With the belly skin off I used a 12" 5/32" bit to drill upwards to get dead center on stamped metal flooring spars, the 1/2" offset is not much and/or is easily corrected for by bending the drill a teensy bit after it has pierced the metal spar so its truer to plumb as it goes through the flooring. Having a helper up top standing on an oversized backer board to keep from chipping the plywood as the drill bit pops through makes it a smooth procedure, though you could weigh down a 7' long board above and do the same thing.
My '73 used these floor screws, do not drill the pilot holes too large as these are self-drilling and use the metal it doesn't cut but shoves out of the way to increase the strength of the threads bite to the screw. Also, some countersinking to get the wedge of the head flush with the plywood might be needed, get a especially hard spot on the plywood and it might strip the threads trying to pull it down flush...
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 09-13-2016, 01:42 PM   #13
Kemblkr's Avatar
All I know is the wafer head from Fastenal do not require a predrill. I would just drill new holes. Locating the original holes would be time consuming at best. Just make sure you have your screw plan established so you don't drill into gray tanks or wires or plumbing. Use the same amount of replacement screws as you removed approximately.
A was actually amazed how easy they went into the framing. Figured predrill was going to be a requirement. Pre drilling would not hurt though depending on the type of fastener. Just set your bit depth the same as the screw length.
Screwing My Bambi? Airrogant General Repair Forum 5 04-30-2014 08:40 AM
Screwing into fiberglass bath ceiling? SummitAir Sinks, Showers & Toilets 4 10-22-2008 11:16 AM
screwing through floating laminate DasAir Floor Finishes 6 04-07-2008 07:02 PM
Screwing into walls? starflyte1 General Interior Topics 2 03-19-2007 06:33 AM
BAL jack, nut keeps un-screwing Kistler Jacks, Stabilizers, Lifting and Leveling 7 06-08-2006 10:07 PM
