Old 01-21-2006, 11:17 PM   #1
Screw holes in Tradewind floor
I just removed a retrofit dinette from my Tradewind that had been secured to the floor by 2 inch drywall screws. Upon removing the screws it seemed that they must have penetrated the floor all the way through in places.
Should these very small holes be filled with Gorilla Glue or something to guard against any incursion of moisture into the flooring?
thanks
John
yochanan is offline   Reply With Quote
Old 01-21-2006, 11:50 PM   #2
C Johnson's Avatar
1965 17' Caravel
1968 28' Ambassador
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Hi John, That sounds like a good fix to me. Pretty small holes so the glue should work. If it just drips out the other side try a fast setting epoxy.
Chris
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Removing the body shell and installing new floor completely - any one done this? williamhenshall Repairing/Replacing Floor &/or Frame 11 03-13-2006 11:21 AM
Question re new floor fitting on our 1958 Traveller williamhenshall Repairing/Replacing Floor &/or Frame 9 06-30-2004 03:08 PM
When lacking a floor to make a template... JrnymnJay Repairing/Replacing Floor &/or Frame 6 11-30-2002 06:28 PM
Front floor area and rebuilding dresser jeanarlene 1969 - 1973 Safari 10 09-05-2002 11:11 AM
Total floor replace 74Argosy24MH Repairing/Replacing Floor &/or Frame 1 06-27-2002 04:05 PM
