Old 05-07-2014, 04:20 PM   #1
Sanity check. Attaching Baseplates to floor to Frame
Hiya. I'm building a canned ham from scratch using Airstream-ish construction methods. 10 feet long by 7 feet wide.
I just want to get a sanity check on my frame so far.
1. I've been bolting the Floor Deck to the metal frame with 3/8 Grade 5 bolts. There will be 5 along the front, 4 along one side (with the door), 2 along the Curb side, 4 along the back edge. That's 15 total. That's 4 more than I originally pulled off it. Does that sound like enough? I guess it has to be I don't have spots in the metal frame to do more. I guess my question is.... grade 8? I'm guessing grade 5 is probably stronger than the the metal frame anyway.
2. On top of the wooden deck are the "baseplates" .040 1.5 x 1.5 x 1.5 aluminum C Channel. The 15 bolts will go through those as well anchoring them to the deck with custom square washers/plates I'm fabricating out of 1/8 inch steel. additionally, every 1.25 inches there will be a stainless steel #10 x 1.5 inch hex head screw going through the baseplates into the deck. The deck is 5/8 subfloor on a 2 x 2 frame. The deck is screw and glue with titebond 3 and PL.
From there it's all Airstream-ish as I will be framing and buck riveting on .032 all clad.
My brother says this is all overkill. But I like overkill.
How does this sound so far?
ID:	211419   Click image for larger version
bass-o-matic is offline   Reply With Quote
Sanity Check PDigiorgio Electrical - Systems, Generators, Batteries & Solar 3 01-01-2014 07:29 AM
Sanity Check to Airstream or Not to Airstream? perryg114 Buyer Guidelines 8 09-09-2011 05:54 PM
Can someone reality/sanity check this plan for me? Slip7 Full-Timing 61 03-08-2011 05:43 PM
How to attaching the floor DanielB Repairing/Replacing Floor &/or Frame 17 01-09-2011 07:21 PM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
