Old 11-27-2005, 02:49 AM   #113
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
Originally Posted by uucal
I just went to InlandRV web site. I did not see a wheel balancer.
It's in the article section. http://www.inlandrv.com/articles/wheel-balancing/
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 11-27-2005, 09:41 PM   #114
uucal
Profile:  2003 25' Classic
North Ogden , Utah
Smile Inland balancer
Thanks for your reply. I must confess to going back later to the site after seeing another ref. to the articles. It looks pretty impressive, but not sure if my 2003 model needs this much attention. But after reading comments about checking wheel balance only maybe I should hook up and get them checked before heading out in January for warmer climes
uucal is offline   Reply With Quote
Old 11-28-2005, 10:57 AM   #115
Jim & Susan
Jim & Susan's Avatar
Profile:  1973 27' Overlander
McDonough , Georgia
Images: 37
Inland Andy, Thanks again for the good info.
It seems part of my problem is what I am calling things. The term "elephant ears" apparently refers to the "cut outs" used in the repair to re-attach the shell to the frame in the rear area around the trunk door.
I suppose I have misunderstood that there was some type of kit available to beef up the steel frame itself aft of the axles.
This portion of the frame (aft of the axles) is the weakest part of the frame. I have the floor completely removed from mine and am in the process of repairing the frame (sandblasting and POR-15 all over). If you reach up and "shake" the trailer (by pushing or pulling on a frame member or such), the frame and shell forward of the rear axle remains steady. Aft of the axles, the whole assembly (shell & frame) wiggles back and forth, as if it were unstable.
I guess I'm looking for a way to make the rear of the trailer more rigid; a way to eleminate or at least reduce the amount of movement on the rear of the coach.
Again, thanks for the help.
To lodge all power in one party and to leave it there is to insure bad government. -- Mark Twain
www.nesa.org
Air No. 6427
Old 11-28-2005, 04:28 PM   #116
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Jim & Susan.
Your correct, about the elephant ear patch.
Beefing up the frame, is not a good idea. First of all, it will add weight to the trailer, rearward of the axle. BAD idea, since that will also reduced the tongue weight.
What you can do, it simple and easy, plus cheap!!!
Remember the basic!!!!
The frame DOES NOT hold up the shell. Instead, "the shell holds up the frame".
Increase the number of bolts in the rear floor channel, at least double, if not triple. Remember to use steel plates at the top of the channel, underneath each bolt, to better redistribute weight. If the original floor channel was held in place with csrews, then replace all of them with 1/4 inch bolts, washers and lock washers.
Add additional rivets to the interior rear quarter panels, 3/16" preferred, especially at the bottom.
Remove the rear rub rail. Add additional 3/16 rivets from the front of the rear quarter panel at the bottom, through the rear plate, and then through the bottom of the other rear quarter panel.
Add the additional gusset outward of the frame as well.
Use plenty of rivets, such as every 3 inches.
That operation, adds considerable strength to the rear shell, which takes care of the problem for you, without adding any appreciable weight, or changing the tongue weight.
Easy enough?
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 11-29-2005, 07:49 PM   #117
wkerfoot
wkerfoot's Avatar
Profile:  1979 23' Safari
1954 29' Liner
Orange , California
...Increase the number of bolts in the rear floor channel, at least double, if not triple. Remember to use steel plates at the top of the channel, underneath each bolt, to better redistribute weight. If the original floor channel was held in place with csrews, then replace all of them with 1/4 inch bolts, washers and lock washers...
Andy,
I am in the process of replacing the floor in my 1954 Double Door Liner. How far apart would you place the 1/4" bolts?
I am considering fender washers on top above the channel and steel plates underneath the floor to prevent any pull through of the bolts. Any comments?
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
Old 11-30-2005, 10:28 AM   #118
Commercial Vendor
Bill.
That's almost an "over kill".
Flush self tapping screws have worked for over 50 years.
Every 6 inches would be outstanding.
Inlandrv.com
800-8777311
Old 12-06-2005, 12:02 PM   #119
volvophile
volvophile's Avatar
Profile:  colorado springs , Colorado
how well are disk brakes ballanced?
I'm currently looking at a 31' with Disk brakes.
I'm thinking the disks would likely to be more ballanced than the drums, seeing as how the entire spinning part is machined.
Any thoughts on this?
volvophile is offline   Reply With Quote
Old 12-06-2005, 05:13 PM   #120
dwightdi
Profile:  1977 31' Sovereign
McHenry , Illinois
Old style disk brakes were terrible to maintain and not reliable. No repair parts currently available. I have a set I took of my 77. Final straw caliper holding frames welds cracked. I have used Kelsy Hayes and Dexter electrics since I took the disks off. Do not know about the new ones.
Old 12-06-2005, 06:52 PM   #121
uucal
North Ogden , Utah
Disk brakes vs drums
Maybe there is a recent or newer engineering mechanical graduate out there with better answers, but my dim memory of mechanics from the late 40's relate to the moment of inertia and angular momentum. These two things are related to the distribution of mass in an object, how far it rotates from the center of rotation. All things being equal, there should be not much choice between either type except for such intangibles as ease of servicing pads vs shoes, etc.
High performance sports cars use disks because they can direct more cooling airflow over the parts, cross drill holes to increase cooling effect, etc. But that should be a minor consideration for a travel trailer.
Old 12-29-2005, 07:30 PM   #122
w5wi
w5wi's Avatar
Profile:  1976 25' Caravanner
1977 31' Sovereign
1969 31' Sovereign
Fort Leonard Wood , Missouri
For some reason when I click on the new kid64's link in the text I go to a "commercial" site that apparently is not linked to you. Please advise.
dale
w5wi is offline   Reply With Quote
Old 12-29-2005, 07:57 PM   #123
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Funny, I had a 31' Excella 500 with the disc brakes and never had a lick of trouble with them. They were always dependable and would stop the trailer and it's TV, a 2500hd, with trailer brakes alone. I'd take the disc over electric drum any day of the week. How do I know? I have a 25' Sovereign with electric drum and it won't stop near as fast as the disc shod trailer.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 09-27-2006, 08:20 PM   #124
airstream74
Profile:  1974 31' Excella 500
Bremen , Alabama
I know this is an old thread, but I am the victim of rear end sag.
I clicked on the link to the photss posted by "thenewkid64", but could not get anything. Does anyone know of a good link for photos on this "reinforcement"?
Thanks for help
airstream74 is offline   Reply With Quote
Old 09-27-2006, 08:57 PM   #125
Commercial Vendor
We have and have had repair parts for the original Airstream Excella-Vac disc brakes, up to and including overhaul of the sync valve and replacement bushings for the calipers, the pads (that we have made), special o-rings, pistons, and the clevis pins, and rebuilt rotors.
We also now have a replacement actuator, that does away with the need for a vacuum supply from the tow vehicles.
Disc brakes, even the original Airstream disc brakes, are far superior to electic brakes ever thought of being.
Inlandrv.com
800-8777311
Old 09-28-2006, 05:49 AM   #126
Jim & Susan
McDonough , Georgia
Images: 37
Thanks for help
Hey there, I've got a picture on another computer, but it will be tonight before I can post it. Do plenty of reading before you attempt repairs, it took me a while to do mine. I used a method very similar to the one Inland Andy described a page or so back, plus added some additional steel back there. Things are nice and sturdy back there now.
Good luck with it.
www.nesa.org
Air No. 6427
Droopy Rear End (Motorhome) smily Mechanics Corner - Engines, Transmission & More... 57 02-10-2004 11:17 AM
Rear End Separation Questions... Morning Dew Repairing/Replacing Floor &/or Frame 24 02-03-2004 11:22 PM
Rear end Sag? Fun-Lovin Repairing/Replacing Floor &/or Frame 2 10-27-2003 09:03 AM
rear end sag bhsl8 Repairing/Replacing Floor &/or Frame 17 07-31-2003 09:36 AM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 05:40 PM
