Old 10-29-2002, 04:27 AM   #85
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
why can't your drums or discs be balanced seperately from the tires?
it would seem that if your brakes were balanced they would stay that way for most of their life.
if you had a balanced brake, then added a balanced tire to the whole assy. it would still be in balance.(?)
i would think that any good machine shop would be able to put your drums or discs on a lathe or arbor and find the heavy spot. then add metal tabs until the unit was even. (if they are bad in the first place)
tires are tires and any good shop can fix them.
i don't disagree that running gear should be balanced, but i think there may be a better answer.
how about "slimeing" the tires? i have heard this method has been in use in long haul trucks for years.
anyone ever try it?
john
Old 10-29-2002, 04:37 AM   #86
74Argosy24MH
Profile:  LOST , Hawaii
Balancing the drums separately would be better. If you balance the tire/wheel/drum assembly and pull the wheel and tire, you need to mark the wheel and drum and make sure they go back on in the same position. If not you are out of balance again.
John
74Argosy24MH is offline   Reply With Quote
Old 10-29-2002, 04:54 AM   #87
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
Good points John HD and 74 Argosy, I have been wondering the same thing. Another point to ponder is that if you balance as a complete assembly, and you have a flat tire and change it, you would be out of balance. Seems to me if the brake drums were balanced at the factory, and the tires balanced when they are mounted to the rims, this would not be a problem. I would thing these things would have to really be out of wack to cause structural problems like this. This discussion seems to be creating more questions than answers!
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 10-29-2002, 05:22 AM   #88
74Argosy24MH
If you have these balanced as an assembly the first thing I would do is take an indelible marker and mark the end of a stud and make a small mark on the wheel next to it. If you have a flat or have to pull the wheel you can put the wheel back on in the same location and it will be balanced. If you add weight to the wheel to compensate for the drum balance and don't get it back in the proper orientation it is going to be as bad or worse than no balance.
John
Old 10-29-2002, 07:24 AM   #89
FranceyS
FranceyS's Avatar
Profile:
Francey's Shimmy and Shake
Regarding Francey's Shimmy and Shake...
Dear FRIENDS:
I want to thank you all for your wonderful suggestions.
If I had not read of the problems involving vibration and drums and so forth on this Forum, I would still be wondering what to do to correct the shimmy problem I had.
If I'd not gotten the great suggestions for curing the problem by those of you generous enough to share your knowledge, I would still be wondering what to do.
I took ALL THE ADVICE and first thing this morning (Tuesday)
I drove down to the tire shop where I'd purchased my tires and described the situation to them. The wheel shimmied most of the way there....
(As you might recall, I'd had the front end aligned right after hitting the road gully and that didn't help at all.)
The tire people found that the rim of the front tire had a small dent in it...they rotated the tires, balanced all the wheels, and put that rim on the back.
They didn't find any other problems that would caused the shimmy and they assured me the problem was solved.
And it was. Not a murmur in the steering wheel on the ride home. WHAT A RELIEF! After reading the truthful facts of what constant vibration can do to damage a vehicle, that really motivated me to get things fixed.
So, THANK YOU ALL for your great help. Most sincerely, Francey
Francey, from East Tennessee
FranceyS is offline   Reply With Quote
Old 10-31-2002, 05:41 PM   #90
JPAIRSTREAM
JPAIRSTREAM's Avatar
, Ohio
Images: 47
JP
JPAIRSTREAM is offline   Reply With Quote
Old 11-01-2002, 05:18 AM   #91
Pick
Pick's Avatar
Images: 36
I checked mine last night, it does have the update, described above. Looks like it has the frame reinforcement in the axle area too. Looks like the previous owners knew how to take care her! Now all I got to do is replace that one questionable tire, and have the balancing done, and I should be set.
Lots of Hot Sauce!
Air # 283
Old 11-01-2002, 11:25 AM   #92
hex
hex's Avatar
Profile:
Arrow Elephant ear Repair Drawing
Thanks JPAirstream for that drawing.
Could you tell us where that came from? and were there more pages?
I also wonder about the channel replacement. Seems that cutting a section out would result in weakness with little or no improvement unless the replacement overlapped the old channel for a foot or so up toward the front of trailer. But you would (I assume) play hell trying to get to that. And of course the shell would be resting in that forward channel section.
Where would one find a piece of "heavier replacement channel" in that curved configuration I wonder?
hex is offline   Reply With Quote
Old 11-01-2002, 02:20 PM   #93
JPAIRSTREAM
, Ohio
Images: 47
Talking
Hex:
Hex I have called and talked to AIrstream on there Tech Support line on this issue. Ths individual I talked to had these in a folder. I asked to get a copie of these. He sent them to me in PDF format I had to take screen captures adn turn them into JPG's.
I agree, But the drawing does not tell you you should weld the overlapping section to the existing bow. The support person did advise this to be done. you would have the lower wrap metal loose to be able to access the forward area.
This is all he sent I assume all he had. never pushed the issue was happy to receive this.
Did not ask this question. SORRY. Maybe the use what the currently are using on there trailers. This is me assuming of course.
AIRSTREAM SUPPORT PAGE is at the provided link here. I have posted this in another post s well. Airstream is very helpful even on there older models.
JP
Old 11-02-2003, 05:12 PM   #94
Fun-Lovin
Profile:
About 2 months ago I repaired the sag in my frame. Turned out that the road side was broken at the rear axle. There are alot of pictures of my repairs and some that andy posted as well.
Greg
1976 Soveriegn 31'
F250 Turbo 7.3L Diesel
WBCCI # 3516
Fun-Lovin is offline   Reply With Quote
Old 11-02-2003, 07:14 PM   #95
POAST
POAST's Avatar
Profile:
Saggy Bottom
If you even suspect a sag, Call and talk to Griffith RV in Oklahoma City. He repaired my 75 model with factory supplied reinforcements and was in process of doing many more at the time. Did great work. FACT Now for rumors etc. I was given the impression that models built in the 70s had this problem. It was overcome in later models by use of larger frame members.
POAST is offline   Reply With Quote
Old 11-02-2003, 08:16 PM   #96
garry
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
sag repair
Griffith also repaired mine and instead of the elephant ears the cut out was much smaller and was covered over with red reflectors that looks like it could have been orignal A/S configuration.
I later found my axles are bad (positive 10 deg) and I am convinced that caused the problem. Will install new axles and have everything balanced this spring I just hope I haven't weakened the fix since I have around 800 miles pulling with bad axles.
If you are even close to OK City I highly recommend Griffith RV he knows A/S and I think he is an authorized A/S repair facility.
Garry
Old 05-08-2005, 10:46 PM   #97
Ron Doda
Profile:
Sag in rear
My 1974 31 Soverign seems to be sagging in the rear from behind the tires to the stern. It looks like the whole trailer drops a couple of inches. My rear bumper is almost touching the ground. I brought it up from Florida in 2001. The bottom aluminum sheet was scraped off. I have a scraped off rear pannel and it sceems that my holding tank is verry close to the ground. My rear bumper looks like it has seperated from the trailer body about an inch. My dad must have repared it at one time or another. I also need an owners manuel so I can figure out how to opperate some of the gizmos. PS it has an orignal 8track! that works
Ron Doda is offline   Reply With Quote
Old 05-09-2005, 08:30 AM   #98
Gordon Watt
Gordon Watt's Avatar
Profile:
Rear Sag
Hi Ron:
There is a lot of info on Sagging Rear ends.
I had the same problem although not as severe. My cost of repair was $1500.00 4 years ago not counting the cost of towing the trailer 1000 miles the a repair facility.
I assume your trailer lived in Florida which will rust the frame and the outrigger frames fail letting the cabin put more pressure on the rear frame. Other reasons are also involved.
Gordon Watt is offline   Reply With Quote
Droopy Rear End (Motorhome) smily Mechanics Corner - Engines, Transmission & More... 57 02-10-2004 10:17 AM
Rear End Separation Questions... Morning Dew Repairing/Replacing Floor &/or Frame 24 02-03-2004 10:22 PM
Rear end Sag? Fun-Lovin Repairing/Replacing Floor &/or Frame 2 10-27-2003 08:03 AM
rear end sag bhsl8 Repairing/Replacing Floor &/or Frame 17 07-31-2003 08:36 AM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
