Old 02-10-2015, 05:45 PM   #1
1973 31' Sovereign
Alsip , Illinois
sag on passenger rear
hi guys i am new to the site and would like any suggestions or ideas regarding i own a 1973 land yacht & it sags in the right rear & right hand side there is a gap by the door area like the walls are pulling away from floor. it is no longer being used as a trailer i have converted it into a mobile bar. any help would be greatly appeciated
thank you
ID:	232114   Click image for larger version
mattyairstream is offline   Reply With Quote
Old 02-10-2015, 09:28 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Welcome to the forums!
Search for "rear end separation." It is likely that you have it, and probably extensive frame failure as well. Did you do the conversion to mobile bar yourself, or buy it this way?
Good luck!
Old 02-11-2015, 06:42 AM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Ok, here is my thought.
The axles if original are shot, the trailer rides rough. Weight might have been added in the very rear of the trailer creating a situation where the back of the trailer has been hammered down.
What you are going to find is that the trailer frame is bent down right where the second axle passes through a notch in the frame.
This happened to my trailer After I had repaired the separation issue and used the trailer before changing out the axles.
I fixed this for little more than the price of the axles by using 20' of 3" angle, a jack, and a welder...
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Passenger side rear view mirror loose dgmelp Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 3 07-16-2012 08:41 AM
Rear sag '75 rear bath Sovereign Ofdtruckie Repairing/Replacing Floor &/or Frame 20 02-08-2012 01:45 PM
Rear Separation and Rear Sag on my '72 mello mike Axles 17 06-16-2005 01:58 PM
Rear sag- or no rear sag? aviontt Repairing/Replacing Floor &/or Frame 14 08-27-2003 05:38 PM
