Old 11-23-2014, 12:33 PM   #1
1977 23' Safari
Carberry , Manitoba
Safari floor repair
I have to make a repair to a small section of floor in the rear curb corner of my Safari. The repair will be in the closet and behind/beneath the toilet. I have removed the rear lower skin beneath the back window and need to remove the lower skin in the closet. Trouble is, to remove this skin, I would have to remove the bathroom door/wall and closet wall as well as the upper skins, something I would like to avoid. As the repair is just in the closet, I am planning on cutting the inner skin about 8-10" above the floor inside the closet to give me access to the c-channel bolts. What would be the best way to make that cut? die grinder with cutoff wheel? Is there any reason why I wouldn't want to cut a piece out of the skin for access?
TIA - Lorry
cp1977 is offline   Reply With Quote
Old 11-23-2014, 01:20 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I've had good results using an oscillating tool to make cuts in aluminum, especially in hard to reach areas. Gives you a lot more control.
As for reasons not to do it, as long as you make a patch that will keep the critters from inhabiting your walls, I think there is no harm.
good luck!
Old 11-23-2014, 03:46 PM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Using a series of holes made with a large hole saw might be an option.
If it gives you the access you need, it can look "clean" and professional.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
J. Morgan is offline   Reply With Quote
Plastic bathroom components crack repair with 3M 4240 semi-rigid plastic repair kit Lance M Upholstery, Blinds, Walls & Interior Finishes 1 05-09-2011 07:11 PM
'69 Safari bath floor repair fotochop Repairing/Replacing Floor &/or Frame 151 01-04-2009 10:52 AM
shop repair of 1970s rear frame separation (non elephant ears repair) RV shop review simonhanbury Repairing/Replacing Floor &/or Frame 49 06-24-2008 09:16 AM
1970 Safari floor & frame repair DTMalloy Repairing/Replacing Floor &/or Frame 6 04-24-2008 01:21 PM
Bathroom Floor Repair John Sims Repairing/Replacing Floor &/or Frame 4 01-09-2003 12:13 AM
