Old 01-25-2012, 09:37 PM   #1
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Rusted off? The whole tongue?! Ever heard of this?
Happened upon this posting for a 34' excella for waaaay less $$$ than I would expect. But the guy says the whole tongue rusted off! He claims it is common. Holy smokes! Is this true? Our similar-vintage trailer has no rust there!
1986 Airstream Excella
Skatiero is offline   Reply With Quote
Old 01-25-2012, 09:52 PM   #2
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
the front end is crumpled a bit. Perhaps it was in an accident that damaged the tongue?
4RXLA is offline   Reply With Quote
Old 01-25-2012, 10:00 PM   #3
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
I've seen it before, typically on trailers that spend a lot of time near the coast. There is likely a lot more rust hidden in the belly pan too. Sad really.
Colin
Colin H is offline   Reply With Quote
Old 01-25-2012, 10:08 PM   #4
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
Tongue rusting off is absolutely not common. I'm with dougsale, probably an accident. Maybe dropped so hard it was bent, cut off, and not repaired? My first question would be does it have a salvaged title?
The NSA -- The only part of the government that listens.
newroswell is offline   Reply With Quote
Old 01-25-2012, 10:16 PM   #5
Chief Chili Cook
newroswell's Avatar
Colin
Colin, you've seen it all though! I love your work.
Old 01-26-2012, 04:14 AM   #6
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I saw one with the tongue cut partway through from battery acid running from one of those front mounted under couch battery compartments.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 01-26-2012, 05:37 AM   #7
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
This 56 trailer rusted off going down the road. Made quite a mess when it hit the ditch.
Name:	Pat's place 028.jpg
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
Shacksman is offline   Reply With Quote
Old 01-26-2012, 05:46 AM   #8
1981 31' Excella II
New Market , Alabama
It is not worth $3900. I paid $5000 for my 81 Excella II and it is in alot better shape than that one although it did have some issues and still has some issues. I am sure there are frame issues at the back as well. I would say it is a parts trailer at best or a total rebuild from the ground up.
Perry
Old 01-29-2012, 10:36 PM   #9
Tool Hoarder
West , California
Uh.. I would stay clear unless you get a better price and you are really handy.
marzboy is offline   Reply With Quote
Old 01-29-2012, 10:55 PM   #10
Colin H's Avatar
1959 28' Ambassador
1949 24' Limited
Peru , New York
Thx,
Colin
Old 01-29-2012, 11:33 PM   #11
Klatawa (to travel)
Klatawa's Avatar
1965 24' Tradewind
Bremerton , Washington
We had a tongue rust problem on our 1965 Tradewind when we gutted and rebuilt it. The rust problem started at the Airstream factory and ended with squirrels. The rust was only at the back end of the tongue in the under body. Airstream boxed the tongue, thats a good thing but they step welded the plate on as the trailer got older the dirt filled the lower inside edge of the plate and instead of the water running out it ran to the back of the tongue and that is where the squirrels come in they built a nest at each end of the tongue with the insulation which held the water on the lower section of the frame. We did not have a problem gutting this trailer if it was not rotten, broken, rusted, missing or squirrel eaten, they chewed strait through solid wood cabinets, nasty creatures.
Klatawa
(Dave & Debbie)
1965 24' Tradewind
2015 Chev Silverado HC
Klatawa is offline   Reply With Quote
Old 01-30-2012, 06:16 AM   #12
r carl's Avatar
Lin , Ne
It may have been towed with a 1 ton with #1200 spring bars.
Old 01-30-2012, 08:13 AM   #13
CanoeStream's Avatar
St. Cloud , Minnesota
Colin
And how! The roadside tongue and frame under the belly pan were shot on my Argosy. I later found out that it spent its life sitting at the Delaware shore. Must have had curbside turned away from the salt spray.
5 meter Langford Nahanni
Old 01-30-2012, 08:38 AM   #14
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
A frame rusting through is not uncommon enough. I bought a 89 31' Excella that had only been pulled a couple thousand and then was parked on a site for a long time. I pulled it 600 miles home. Upon more careful inspection I found that I could stick a screwdriver though the A frame on one side right behind the caulk where it enters the trailer. I took it to Jackson Center and had a new A frame installed. They also fixed the leak in the Vista Window that probably caused it. It was also below a battery compartment that did not have a battery in it so I do not know if that was a factor. Reason I say it is not real uncommon is that I had seen a post on this forum from another person that had to have it done and I have talked to a fellow who had and A frame break while on a caravan in Alaska and had to have it repaired.
Old 01-30-2012, 09:32 AM   #15
overlander63 was actively using his Sovereign when he discovered the frame coming apart - 1, 2, 3
Knowwhuddimean? That pic is just scary.
Old 01-31-2012, 08:43 AM   #16
Chief Chili Cook
newroswell's Avatar
Wow, I see now why the east coast likes to buy their vintage vehicles from CA & desert states.
Old 01-31-2012, 01:46 PM   #17
Noob
JazzDad's Avatar
2009 22' Sport
Columbus , Texas
That'll buff out!
All kids are gifted; some just open their packages earlier than others. - Michael Carr
JazzDad is offline   Reply With Quote
Old 01-31-2012, 01:52 PM   #18
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
Bill M is Correct...
We've all seen it enough of it to know it's not uncommon. enough.
No, I can provide a statistical analysis, but I have seen it in 25% of the Airstreams I have owned.
Ken L
2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 02-01-2012, 09:30 AM   #19
Eric H's Avatar
1974 23' Safari
1947 25' Spartan , Manor
It's funny to see this post, my Safari has pretty deep rust spots on the tongue that I'm welding today or this weekend, about to head to the shop to buy the steel!
My Safari did in fact live in VA Beach for most of it's life, and the rust throughout the frame has kept me busy welding. My Spartan which is almost 30 years older then my 74 Safari has a frame that's in better shape!!!!
ID:	150003   Click image for larger version
Eric H is offline   Reply With Quote
Old 02-01-2012, 09:35 AM   #20
Alumaholic's Avatar
Images: 36
Life's a Beach
My '76 23' Safari with the rusted frame was parked in an RV Park at Atlantic Beach, NC. Eric H's pictures gave me a real feeling of deja vu
Ken L
1995 Classic Excella Tongue Weight mybyebye Hitches, Couplers & Balls 2 01-03-2012 10:48 PM
Tongue weight danlehosky Hitches, Couplers & Balls 7 10-29-2011 04:16 PM
Vintage Tongue Jack - Reese IndyAnne Jacks, Stabilizers, Lifting and Leveling 11 10-19-2011 01:32 PM
Ultra Fab Odyssey 3000 Tongue Jack indy Jacks, Stabilizers, Lifting and Leveling 0 04-15-2011 09:49 AM
Need Tongue Jack - Suggestions? kj78133 Jacks, Stabilizers, Lifting and Leveling 16 02-23-2011 05:55 PM
