Old 09-16-2014, 04:40 PM   #1
2004 16' International CCD
Bozeman , MT
Rotten floor in storage compartment
Hi there,
I found that the rear storage compartment in my 2004 16foot bambi is wet and rotten (see photo after I removed all rotten wood and insulation). In the past it had gotten wet there do to a shower leak but the airstream has been sitting for 11 months and I only used the shower a few times (6 showers) on a recent trip last week and the subfloor was completely wet and rotten when I checked. Including insulation underneath it. I imagine that the leak is caused by something else. We had a lot of rain in Montana last month and I am wondering if water is coming from the outside. I don't see anything obvious anywhere. There are no water streaks or obvious entry and exit areas. The water was underneath the linoleum and only obvious when I started digging with a knife. Any idea what places I should check? Could the leak be between the outside and inside aluminum panels?
Thanks for the help!
Paolo
Name:	2014-09-14 18.51.29.jpg
marchesi is offline   Reply With Quote
Old 09-16-2014, 05:01 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Lack of any caulking or gaskets where the bumper storage lid meets the body of the trailer is a common cause of this problem. If you search the forums for "sealing rear compartment" or "rear compartment leak" it should turn up what has been done to fix this. I have not had this problem withi my 2001 (knock wood) but it generally involves removing the molding and its chrome insert, and the bumper top and caulking the area.
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 09-21-2014, 03:37 PM   #3
Bozeman , MT
Al, thank so much for the reply! Yes, looks like that's where the leak is coming from.
Old 10-04-2014, 07:52 PM   #4
Bozeman , MT
Hi Al, Just returned home with my Airstream and searched forum for "sealing rear compartment" or "rear compartment leak"and I don't seem to find what I need. Am I not searching correctly?
Old 10-04-2014, 08:30 PM   #5
sandlapper's Avatar
1993 34' Excella
York , South Carolina
marchesi, did you try the advanced google search??
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 10-04-2014, 09:48 PM   #6
Here you go
http://www.airforums.com/forums/f456...de-109059.html
Al
S/OS #004
Newbie needs advice on fixing rotten floor Lyvettely Repairing/Replacing Floor &/or Frame 32 11-26-2014 01:48 PM
What to do about my rotten floor??? utahredrock Repairing/Replacing Floor &/or Frame 15 11-03-2011 12:38 PM
rotten floor by door colin57 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 01-05-2008 09:17 AM
What to do? Rotten floor cbl3030 Repairing/Replacing Floor &/or Frame 13 08-24-2006 12:25 PM
Rotten floor BurnBound Repairing/Replacing Floor &/or Frame 16 02-05-2006 08:03 PM
