Old 03-22-2015, 08:38 AM   #1
1997 30' Excella
Corpus Christi , Texas
Rotted floor between door and sink corner
Will attach pics later. Checking door for possible cause. Door needs realigning. Any other causes possible that you can think of?
Knudsvig is offline   Reply With Quote
Old 03-22-2015, 12:43 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Door must be square before shaping curve
Peace and Blessings..
Channing
WBCCI# 30676
Old 03-23-2015, 09:04 AM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
What year/model of trailer are you looking at?
Old 03-23-2015, 09:24 AM   #4
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Door leaks are common .. but please add the info mentioned above..so we can help u
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 03-23-2015, 11:07 AM   #5
2002 22' International
Corvallis , Oregon
We have a 2002 22' International we have spent in excess of $10,000 have our floors replaced. They are a particle board type of material. If I had realized earlier leeks needed to be looked for I would have been smarter.
The trailer was built with these moisture damaging "subfloors", covered with nice thick carpet padding, beautiful light carpet, then covered with a double thick layer of plastic, all furnishings were then installed preventing observation of leaks until the damage was done.
boblind is offline   Reply With Quote
Old 03-24-2015, 09:21 AM   #6
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
10,000? wow someone saw you coming
AIR #005
retired!
Old 03-24-2015, 09:57 AM   #7
Corvallis , Oregon
I should have purchased a moisture detector when we bought the TT.
This is a fine example of a design flaw, carpet in a TT w/I a method for leaning.
The first realization was setting the unit up after dark in an area where a dog had been left tied up and not cleaned afterward.
Old 04-05-2015, 02:37 PM   #8
1997 30' Excella
Name:	ImageUploadedByAirstream Forums1428266159.212682.jpg
ID:	235659Click image for larger version
Name:	ImageUploadedByAirstream Forums1428266182.465725.jpg
ID:	235660Click image for larger version
Name:	ImageUploadedByAirstream Forums1428266199.234552.jpg
ID:	235661Click image for larger version
Name:	ImageUploadedByAirstream Forums1428266227.137943.jpg
ID:	235662Click image for larger version
Name:	ImageUploadedByAirstream Forums1428266249.841139.jpg
Old 04-05-2015, 06:52 PM   #9
2009 25' FB Flying Cloud
Oregon City , Oregon
We just discovered water damage in a similar location in our 25ft Flying Cloud (front bedroom). I'm going to have to rip up the vinyl flooring, replace it with marine grade plywood or true pressure treated ply, then reapply a different type of floor covering. Before any of this I'd really like to know where the water is coming from. Were any of you able to trace the incursion to its source?
I'd appreciate all of your advice.
Thank you!
BTUs4You is offline   Reply With Quote
Old 04-05-2015, 08:54 PM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Hey, y'all... I have used 'Git Rot with a lot of success... do not replace unless the structure is gone.. the 'Git Rot may be able to penetrate if applied properly..and save you $$$ and get you 'camping' sooner!!!
Channing
WBCCI# 30676
Old 04-05-2015, 09:03 PM   #11
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Knudsvig-Check the kitchen faucet and lines. Also check the lines and the water filter for the filtered water tap. That's where it looks to me to be coming from. We have a '97 as well and that is where ours was leaking. We ended up replacing the main faucet. Cured the problem.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 04-05-2015, 10:12 PM   #12
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Plumbing. The bane of the mobile life. But none would choose to be without it.
Old 04-16-2015, 04:12 PM   #13
1997 30' Excella
This weekend is maintenance weekend. Going to rip out carpeting, check plumbing, tighten door, and I am going to STOP this leak!! Next, replace city water connector. Want to make sure this trailer is DRY!!!
Old 04-29-2015, 08:49 PM   #14
1997 30' Excella
4 days post sealing the eyebrow where we found a leak. Click image for larger version
Name:	ImageUploadedByAirstream Forums1430362140.324668.jpg
It's still damp and soft. Any ideas how long it will take to dry?
Repair of rotted floor area dynastream Repairing/Replacing Floor &/or Frame 2 03-22-2011 05:28 PM
What to do? Floor rotted. Breadbug Floor Finishes 20 01-26-2011 01:32 PM
replacing rotted floor sections on '69 Overlander jayg Repairing/Replacing Floor &/or Frame 4 10-30-2010 11:11 AM
I removed the rotted floor today! chris's 67 Repairing/Replacing Floor &/or Frame 7 03-31-2007 12:39 PM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
