Old 12-20-2008, 12:43 PM   #1
FT RVing
lebolewis's Avatar
Profile:  1976 31' Sovereign
Always searching for a place w/low Humidity , FT RVing, N & S, E & W, & in between
Rot Doctor - the fumes
Ok, I've done my research and decided on "Rot Doctor" as the product to use.
I plan to treat a bathroom section of about 2' X 2' in a well ventilated area, including a fan blowing over the surface, and using a 2" wide bristle paint brush.
Will I need to use the Respirator? Right now, my plan is "no Respirator".
Any advice? Bill
When you get a chance to "Dance" or "sit this one out".......I hope you DANCE!
lebolewis is offline   Reply With Quote
Old 12-20-2008, 01:32 PM   #2
Janet's Husband's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
1977 Argosy 24 Rear Door
Eastern , Washington
Any advice? Bill
If you feel the need, use one with Organic Vapor filters. You can get them from a local auto paint shop about $50.00.
Peace
Gary
Janet's Husband is offline   Reply With Quote
Old 12-20-2008, 01:36 PM   #3
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 65
Airstream Registry
The stuff is nasty. I would recommend one that is designed for organic fumes. After I used the stuff, I kept the trailer well ventilated (fan) for a couple of days.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 12-20-2008, 02:10 PM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Yes, Rot Doctor is good. Realize that this high solvent product soaks in well but doesn't completely embed the wood with resin -- there are plenty of microvoids. I'm not sure that makes a practical difference -- it soaks into all the wood cellulose fiber and shields it. It's so much better having this protection. I like it.
I've used an organic cartridge respirator for a number of reasons. I just like it better. They are not overly expensive and are comfortable up to a point even in warm sweaty weather. I don't have a beard and the seal is so good you can hardly smell the stuff.
Under any conditions you must have plenty of air exchanges to actually deliver oxygen to you. I'd probably think more of having the fan direct air from elsewhere into your work space and wouldn't worry about pointing it at the work itself. Rot Doctor goes on quickly and you'll be soaking more and more into the surface. On an area like that you'll maybe remix once to make up more. But you'd be there for maybe 5 minutes?
Epoxy is a contact skin sensitizer like poison ivy. You can be sloppy a few times without any effect. And then watch out. You literally won't be able to use un-set epoxy ever again if you sensitize yourself. The solvent in Rot Doctor messes up normal rubber gloves. I used thin utility nitrile gloves. It will mess with them if you get some on them. Have some more gloves at hand to change and wash your hands right after.
There is little advantage to using the more solid boatbuilder epoxies. It really doesn't provide any more security. Moisture control for your shell & bathroom is still #1! Let us know how it turns out.
BobStream
...You really don't know someone 'til you've had recess with them. ...Alex Ziton, age 8
CanoeStream is online now   Reply With Quote
Old 12-21-2008, 09:07 AM   #5
FT RVing
lebolewis's Avatar
Respirator
Thanks for all the advice.......you have changed my mind.....I will be using a Respirator and gloves. Bill
Old 12-21-2008, 12:36 PM   #6
danalee's Avatar
Profile:  1978 29' Ambassador
Walnut Cove , North Carolina
Images: 30
When it doubt its always best to go for safety-use the repirator!
Dannie
The Silver Queen
danalee is offline   Reply With Quote
Old 12-22-2008, 10:10 AM   #7
rogerdodger's Avatar
Profile:  1981 27' Excella II
clovis , California
Ditto! I used it in the rear, with the door open, and I was outside, so respirator was not needed. When I went inside, WOW, strong, so I vented the AS and stayed out for 3 days.
Roger
Air# 29488
WBCCI# 2582
W6ROG
TV-2005 Dodge Durango Hemi
rogerdodger is offline   Reply With Quote
Old 12-22-2008, 12:51 PM   #8
Lumatic's Avatar
Profile:  1971 25' Tradewind
1967 24' Tradewind
Estancia , New Mexico
Unless you can hold your breath for a really, really long time use a respirator. I confess when I used Rot Doctor I cheated a little bit. But then again, I survived the 60s.
get off the road hippy
Lumatic is online now   Reply With Quote
Rust Doctor... Anyone tried it? campngirl Repairing/Replacing Floor &/or Frame 3 03-31-2008 07:56 PM
Need help with bad furnace fumes!! flyingscot Furnaces, Heaters, Fireplaces & Air Conditioning 10 10-15-2007 08:05 PM
Generator Fumes jim8860 General Motorhome Topics 5 04-26-2004 12:33 PM
Doctor Box Pahaska Our Community 7 11-18-2002 08:53 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
