Old 04-29-2011, 11:05 AM   #1
tracker
tracker's Avatar
1969 23' Safari
crescent city , California
rot doctor questions
I have read several treads on the use of rot doctor but Iam still confused on just how much damage this product was designed to repair. I have seveal area some larger than others where the holes in the subfloor go all the way thru and other areas where only the surface of the plywood is de-laminating what would be the best use of this product in this case?
tracker is offline   Reply With Quote
Old 04-29-2011, 12:38 PM   #2
Emerson75's Avatar
1975 25' Tradewind
Hanover , Pennsylvania
I would recommend visiting their website. They have quite a bit of information on different levels of repair possible, and the steps required for each. It's quite impressive just how much can be salvaged. If you have questions, don't hesitate contacting them. I did before I purchased, and the the guy I spoke with (I cant remember his name) was very friendly, helpful, and showed no pressure to purchase. When I mentioned Airstream, he was not surprised and seemed quite familiar with Rot Doctor's use in them.
Good luck,
Eric
Eric, Stacey, Easton, Annabelle, Gretzky (boxer), & George Bailey (basset hound)
1975 Tradewind - Family owned and operated since 1975
2005 Chevy Tahoe Z71
Emerson75 is offline   Reply With Quote
Old 04-29-2011, 01:56 PM   #3
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
If you have areas where there are holes in the wood, those areas should be scabbed with new pieces of wood. Rot Dr is mainly for areas where you have soft wood or uneven surface areas. Rot Dr sells a product that mixes with sawdust to fill in areas that need it.
Depending on how many holes you have in your subfloor, your trailer may be a candidate for a completely new subfloor.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Please forgive me funkill Repairing/Replacing Floor &/or Frame 22 04-07-2011 08:11 AM
Pergo Flooring Bigdaddy_2 Floor Finishes 30 04-06-2011 08:33 AM
stopping the rot hertfordnc General Interior Topics 2 01-29-2011 05:42 PM
newb frame rot question 386kustoms Repairing/Replacing Floor &/or Frame 5 01-24-2011 07:01 AM
