Old 08-12-2016, 11:07 AM   #1
1977 21' Globetrotter
Vancouver , British Columbia
Riveted the floor to frame?
Has anyone tried riveting the wooden subfloor to the frame, rather than just bolting it? or instead of bolting it?
I am about to bolt the subfloor down and realized that it would be easier to rivet the sheets to the frame. Is there a problem doing this?
takmanii is offline   Reply With Quote
Old 08-12-2016, 11:24 AM   #2
ericpeltier's Avatar
Superior , Colorado
I think of rivets for holding thin things together. Going through 5/8 plywood and (maybe) 1/8 steel as pretty thick for a pop rivet.....
But, good and pertinent question, as I'm a few weeks from doing as you say - laying plywood.
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
ericpeltier is offline   Reply With Quote
Old 08-12-2016, 11:34 AM   #3
I was wondering because they have rivets that are long. I was planning on sealing the seams, between the plywood with staples, like they had originally or else fibrglassing the seams. The rivets seem like a simple solution to holding it down.
If it doesn't work, though, tapping and bolting the floor is easy enough.
Thanks for the response
Old 08-12-2016, 12:39 PM   #4
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
The 70's trailers used a self-drilling, self tapping screw to hold the floor down. I bought new ones that were identical to the originals, and screwed down my floor quick and easy. I am certain that these screws have greater strength than a pop rivet would. Just remember that there si a lot of flex to your frame and movement to the complete structure. You don't want pop rivets shearing underneath your flooring and allowing your subfloor to float, rattle, and squeak.
good luck!
Old 08-12-2016, 02:45 PM   #5
Thanks, That makes sense.
Old 08-13-2016, 09:53 AM   #6
Superior , Colorado
The description on this page is very helpful
http://www.vintagetrailersupply.com/...-p/vts-387.htm
2012 Nissan Armada
Most of China
Old 08-13-2016, 02:13 PM   #7
1979 23' Safari
Wayland , New York
Though you do need to drill pilots for these ones I liked the larger heads. Personal choice.
http://odmrv.com/catalog/index.php?m...roducts_id=638
The ones ericpeltier mentioned can usually be found in the big orange or blue hardware store on the big wall of screws.
HiJoeSilver is offline   Reply With Quote
Old 08-13-2016, 11:36 PM   #8
Thanks again,
At those prices and with it being so simple, it just makes sense to do it correctly.
Old 08-22-2016, 09:00 PM   #9
Kemblkr's Avatar
2003 22' International
South Bend , Indiana
You should use 1/4" x 1 7/16th inch wafer head screws to screw the subfloor to the frame everywhere but the perimeter. The perimeter should be bolted through the channel and subfloor with grade 5 or grade 8 1/4" bolts with nylock nuts.
Kemblkr is offline   Reply With Quote
Rosie the Riveted: '57 SOTR renovation asta2 1955 - 1959 Sovereign 25 03-09-2020 08:51 AM
riveted wheel safe? project66 Wheels, Hubs & Bearings 2 08-01-2012 10:21 AM
1967 Airstream 26' Overlander. Riveted construction. eBay Watch Airstreams on eBay 2 07-25-2009 10:01 AM
Riveted Parts? GlenCoombe Classic Motorhomes 10 03-02-2008 08:42 AM
screwed and riveted Cruiser Ribs, Skins & Rivets 4 05-14-2003 06:05 PM
