Old 12-06-2017, 01:05 AM   #1
1970 25' Caravanner
Incline Village , Nevada
Rigid foam board insulation in belly..XPS or EPS?
Have read through a lot of threads about what, if any, insulation to use under floor.
Seems to be many ideas on this but am curious about choice of closed cell rigid foam board. Do you go with the extruded polystyrene (XPS) or expanded polystyrene (EPS)? Have watched videos and read testimonials on both but they are made by the suppliers and the bias is obvious with each pointing out flaws and false claims of the other.
For 2" thickness 4'x8' sheets :
The orange store carries Foamular (XPS). rated R-10 for $32.95
The blue store carries R-tech (EPS). rated R-7.7 for $21.99
What are other pros/cons of each? Would love to hear from anyone who has installed either as to their experience over time. Or anyone who uses either routinely.
Jeremy9107 is offline   Reply With Quote
Old 12-06-2017, 09:39 AM   #2
AL’ UM- MONEY's Avatar
1976 31' Sovereign
2000 33' Land Yacht
Ball Ground , Georgia
What I'm doing
I can't help you because I did not do any research. However I am heading out to the shop now to start installing two inch pink form boards that came from the Orange store. I usually purchase from the blue store but they only had one inch in stock so that was the deciding factor. Mine cost $36.00 per sheet so it seems you got a better deal. I'm redoing a 1969 31 foot sovereign and bought a case of liquid nails and a box of 21/2 screws to hold it in place. Not sure if this is the best method but after pulling a nasty belly pan and awful fiber glass on my back my patience is less then when I started so I hope this will work out.
A husband is the biggest baby you will have and take the most adult supervision.
Gene and Elaine Thomason
Ball Ground Ga.
1976 31 foot Sovereign
2011 GMC 2500HD Denali
6.6 Duramax Diesel
AL’ UM- MONEY is offline   Reply With Quote
Old 12-07-2017, 12:51 AM   #3
1970 25' Caravanner
Personally (having no expert knowledge) I like the pink stuff better. But I have access to the R-Tech for less than $10 per sheet. Thinking the lower R value is worth the savings but want to make sure it's not a far inferior product in other ways.
Old 02-17-2018, 07:18 AM   #4
blickcd's Avatar
Milford , Ohio
I used the 2" XPS, which was green, and came from the 'blue store'.
My trailer is a rear bedroom and I installed this insulation from the holding tank enclosures all the way back to the rear cross member.
As far as the difference in R-value goes, I don't think that matters a whole lot so go with the cheaper option. Consider that the installation process, piecing it in between outriggers and frame members, and leaving small gaps where edges meet the frame so any moisture could drain out... Its not perfect and air tight.
That said, having insulation under the floor does make the interior more comfortable and I would say is worth the effort.
Christopher
Its a camper, therefore it leaks.
blickcd is offline   Reply With Quote
Old 02-19-2018, 10:57 PM   #5
1970 25' Caravanner
blickcd. Thanks. Happened across some free Polyiso insulation but still debating on whether to use it for under the floor. It has the best R value of any of the rigid foam board types but will absorb water...would prefer the pink or blue extruded polystyrene however. Have read is best to seal all gaps with spray foam, but to your point think it would be best just to get as close to frame and cross members as possible and allow that gap for water escape.
Michelin XPS RIB vs. LTX M/S2 Echelon73 Tires 103 02-29-2016 06:55 PM
Insulation- Prodex or Foam Insulation Board? Danny Z General Interior Topics 7 08-26-2015 08:21 PM
Plastic bathroom components crack repair with 3M 4240 semi-rigid plastic repair kit Lance M Upholstery, Blinds, Walls & Interior Finishes 1 05-09-2011 07:11 PM
Michelin XPS Ribs (225/75x16) on our 19-foot Bambi Phoenix Tires 16 01-29-2011 11:32 AM
Why gas connections rigid copper? Splitrock LP Gas, Piping, Tanks & Regulators 15 09-29-2010 01:22 PM
