Old 11-24-2011, 09:48 PM   #57
Tool Hoarder
West , California
Originally Posted by BB 55 Bubble
2 inch strips of foam board insulation. I'll pic it when I get home.
That would be sweet thanks. That is a project in my very near future. I am just waiting on a friend to help me redo the rear lower pannels and buck some rivets.
marzboy is offline   Reply With Quote
Old 11-24-2011, 10:50 PM   #58
worldinchaos's Avatar
1959 17' Pacer
Long Beach , California
I had the same issue- and after my friend helped me buck the rear streetside to replace the cruddy exploding olympics, I then proceeded to do 3/4" deep foam strips 2-3" wide, on all sides adjacent to metal ribs. I also filled the space between to make the air spaces no larger than 8"x12". This was then topped off with the reflectix bubble wrap, using spray adhesive and foil tape. Others can probably comment better, but my lesson learned was to use 1/2" deep strips next time , especially on the endcaps where there is less than a 1" gap in some places.
Just some food for thought.
- Peter (and Marie)
TAC CA-15
1959 Pacer 18' Renovation - Knight in Shining Armor
Our Adventure Blog - Documenting our backpacking, hiking, camping, and Airstreaming
(still updating, haven't gotten to the Airstream trips yet)
worldinchaos is offline   Reply With Quote
Old 11-24-2011, 10:51 PM   #59
BB 55 Bubble's Avatar
1955 16' Bubble
Bend , Oregon
Here is a roof section with the foam board up. I glue this in on the foam.
Ever notice an Airstream resembles a piggy bank
BB 55 Bubble is offline   Reply With Quote
Old 11-24-2011, 10:56 PM   #60
1955 16' Bubble
Bend , Oregon
With 1/4 inch foam the sandwich is layered like this. Outer wall skin, calk, foam board, calk, insulation, calk, foam board, calk, inner skin wall.
Call is very expensive. Best I have found that attached to metal is the Loctite power grab heavy duty construction adhesive.
I accidentally left some on a pannel and it was very hard to remove.
Old 11-24-2011, 10:57 PM   #61
1955 16' Bubble
Bend , Oregon
I talked to the manufacture of the insulation. The best R value is achieved by a air void on each side of the insulation.
Old 11-25-2011, 09:43 AM   #62
Tool Hoarder
West , California
Thanks i will! I have 2giant rolls of Prodex in my garage that are waiting on installation. Cant wait to get back at it. I planned on useing 1/4" strips of foam board. I just want to get this thing done and sealed before the first of the year.
Old 11-28-2011, 11:28 AM   #63
1955 16' Bubble
Bend , Oregon
Do not use spray adhesive for bonding. I called Loctite and inquired about using it when I read it on a previous post here. It will not stay bonded over time and will fail in the application of connecting foam, aluminum, and insulation.
Old 12-01-2011, 12:03 AM   #64
1955 16' Bubble
Bend , Oregon
End cap up. Getting there. 3/4 of the insulation done. I have. Burned through 18 tubes of calking. What the heck. It's only a small trailer I thought to my self. How much could I need. Famous last words.
Just got to dig that 70's sea-foam green paint. Just missing the dingle berries around the window. Dad said it was all the rage when he painted it.
Old 12-01-2011, 09:06 AM   #65
Tool Hoarder
West , California
Nice progress. Yes I have many famous last words like " We should get this wrapped up in a year honey" or " all I gotta do is a few rivets." Just got my end caps down, seems like they wont go back up so eaisly Advice?
Old 12-01-2011, 09:25 AM   #66
1955 16' Bubble
Bend , Oregon
Mine where tight. The foam is compressible. Myself and a neighbor first lined up a hole on the edge closest to the vent as close to the center as possible. Then with some massage along the left and right on the same side I did 2 on each side. The ones along the bottom were the toughest. With both of us pushing in the direction it was needed I was able to line up the hole. It was a struggle but after those rivets it was a lot easier. I then placed 2 above the front window. Lining up the holes was paramount in my brain. Any questions just fire on back.
Old 12-01-2011, 07:33 PM   #67
Tool Hoarder
West , California
Mine where tight. The foam is compressible. Myself and a neighbor first lined up a hole on the edge closest to the vent as close to the center as possible. Then with some massage along the left and r on the same side I did 2 on each side. The ones along the bottom were the toughest. With both of us pushing in the direction it was needed I was able to line up the hole. It was a struggle but after those rivets it was a lot easier. I then placed 2 above the front window. Lining up the holes was paramount in my brain. Any questions just fire on back.
So do you feel that it was more of a problem because of the thickness of the foam strips?
Old 12-04-2011, 11:41 PM   #68
1955 16' Bubble
Bend , Oregon
No. I think that after a shell off it is due to small differences in the shell positioning. I just placed the major roof panel in yesterday. It was even more difficult than the end caps. As far as I can tell the foam was easy to compress in and make fit. I tested this theory and found I can compress by hand the foam down to 1/2 it's original size. So.... I think that it is the shell that is different. I did note that when I finally gave up an a perfect line up that the holes where very closes an I drilled them out. I switched from 1/8 inch rivets to the next size up.
Old 12-05-2011, 08:28 AM   #69
Tool Hoarder
West , California
Thanks I am trying to plan a head to the next project so this helps a lot!
Old 12-22-2011, 08:16 PM   #70
1955 16' Bubble
Bend , Oregon
Paint is done. Thank god, that sucked. It looks good though. I also got most of the lights up.
ID:	147482   Click image for larger version
New Bubble smallfry 1955 - 1957 Bubble 4 08-17-2003 06:49 AM
Stripe on Bubble??? kzener40 Airstream Motorhome Forums 11 09-12-2002 06:40 AM
New tires for my 1956 Bubble.... kzener40 Tires 8 07-27-2002 12:41 PM
1957 Bubble International... BobbyW Our Community 0 05-18-2002 09:56 AM
aluminum restoring rdm Cleaning, Stripping & Polishing 1 02-27-2002 11:37 AM
