Old 02-12-2011, 08:54 PM   #1
StPierre's Avatar
1965 22' Safari
Rescue , California
Replacing the floor
We started our floor replacement today. We were able to remove the front section in one piece. We used it as a patten, and were able to install the new piece without much problem. We flared the sides a bit to fit it in.
Does anyone know if the front and rear radius are the same on a 65 Safari? We could then use the front pattern for the rear if it is the same. Our original rear flooring was totally rotted.
The St Pierre's
StPierre is offline   Reply With Quote
Old 02-12-2011, 08:57 PM   #2
Central , Mississippi
Just today I checked my '63 Overlander....front and rear don't seem to be the same...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 02-12-2011, 10:18 PM   #3
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
Nothing on airstreams is the same. My wheel wells are different, the front and back are different, when I find something symmetrical and or even I will let you know.
ddstech is offline   Reply With Quote
Old 02-14-2011, 11:20 AM   #4
tracker
tracker's Avatar
1969 23' Safari
crescent city , California
I have a 69 safari that I need to patch the floor on can you tell me how wide the sub flooring sections are? I would like to limit the removal to a section below the window on the side. Also did you have to remove the banana wrap to remove the belly pan?
tracker is offline   Reply With Quote
Old 02-14-2011, 11:32 PM   #5
StPierre's Avatar
1965 22' Safari
Rescue , California
Replacing the floor
Tracker I cut the new floor at 88 1/4 inch I'am not sure what year they changed to a wider body. Also I did not have to remove the bannana wrap to drop belly pan . The street side was removed first . Hope this helps .
The St Pierre's
Old 02-15-2011, 07:24 PM   #6
The few places that were to measure left in my '63, all were 88" wide
Old 02-23-2011, 08:39 PM   #7
StPierre's Avatar
1965 22' Safari
Rescue , California
We have finially finished installing the sub floor! By far the hardest part of the job was removing the bolts and screws from the 'C' channel. After installing the elevator bolts, what do you think is the best filler product to use?
It is exciting to have the Safari closed up again so the racoons can't make nest with the insulation.
The St Pierre's
Old 02-23-2011, 09:54 PM   #8
Splitrock's Avatar
Sioux Falls , South Dakota
What are we filling?
Old 02-24-2011, 07:36 AM   #9
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Filler
I've seen that some have used Bondo and is what I will probably use to fill the elevator bolt holes that are countersunk.
SilverHoot is offline   Reply With Quote
Old 02-24-2011, 07:52 AM   #10
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Bondo is the best. Polyester resin, will encapsulate the head and help prevent rusting, plus you can sand it flush. Just get ready to do a bunch at the same time, and leave it slightly proud, then use a heavy grit sandpaper as it gums up the paper easily. Wait at least a day to sand to allow it to cure fully, or it will be a gummy mess as you try to sand.
robwok is offline   Reply With Quote
Old 02-24-2011, 07:53 PM   #11
StPierre's Avatar
1965 22' Safari
Rescue , California
The recessed elevator bolts
The St Pierre's
Old 02-24-2011, 07:56 PM   #12
StPierre's Avatar
1965 22' Safari
Rescue , California
Looks like Bondo it is . Thanks for the help
The St Pierre's
Old 03-14-2011, 10:34 PM   #13
StPierre's Avatar
1965 22' Safari
Rescue , California
Subfloor
We have finished the subfloor. So far we have replaced the axel, fixed the frame, added a gray tank and replaced the subfloor. Next repair the tail lights!
The St Pierre's
Old 03-14-2011, 10:40 PM   #14
WOW!
Thats some top notch craftsmanship!
What gray tank did ya' use?
Old 03-15-2011, 01:41 AM   #15
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
We're about to dig into this. Ugg, I'll post after we pull up the shag carpet.
bhayden is offline   Reply With Quote
Old 03-15-2011, 10:41 PM   #16
StPierre's Avatar
1965 22' Safari
Rescue , California
gray tank
We used a Ronco Plastics 17H 25 gal tank. Even though I woke up some nights thinking "what the heck"? So far it has turned out all right and it has been fun.
The St Pierre's
Old 03-15-2011, 10:47 PM   #17
Splitrock's Avatar
Why did you wake up and think: "what the heck"? Are you having gray tank remorse? This must be a warning . . . and I've been sleeping soooooo well.
Old 03-16-2011, 06:01 AM   #18
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
I've woke up many nights thinking about lots of different parts of the Cruiser. Don't let it become a habit.
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 04-28-2011, 12:53 PM   #19
tracker
tracker's Avatar
1969 23' Safari
Iam about ready to start removing the rotten sections of my sub floor. I would like to do what you did and use the old front section as a templet if I can get out in one piece. I understand the elevator bolts that hold the plywood down where it passes under the "c" channel but I don't see how the other side of the subfloor is attached whwe it butts up to the next section of plywood is it screwed in place from under the trailer?
Old 04-28-2011, 02:43 PM   #20
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Tracker, There are elevator bolts in the center area also, I cut many of these off with a small angle grinder or if you can get to the nuts on the bottom I snapped quite a few off with a wrench by tightening them. Wasn't really to much fun! A big sheet of cardboard makes a good template also.
Good luck
Doug
1965 safari, 22', floor repair
Aft relief tube dripping through floor below sink kaiaua 1974 - 1979 Sovereign 5 02-21-2011 11:21 AM
The frame is ok ~ Patching the floor. LawChick Repairing/Replacing Floor &/or Frame 12 01-30-2011 03:39 PM
Replacing center roof vent in a '79 blickcd Roof Vents, Skylights & Fans 1 01-29-2011 05:58 PM
Fresh water tank relief valve "bumps" above floor? DanielB Fresh Water Systems 12 01-19-2011 07:00 PM
How to attaching the floor DanielB Repairing/Replacing Floor &/or Frame 17 01-09-2011 08:21 PM
