Old 01-27-2015, 08:09 AM   #29
StPierre's Avatar
1965 22' Safari
Rescue , California
Redsled88 I used a body filler with strands of fiberglass , I found it at a auto paint store.I used it on the inside and out side of the housings,so far still looks good after some long road trips
The St Pierre's
StPierre is offline   Reply With Quote
Old 02-04-2015, 11:24 AM   #30
(-1 Rivet_
REDSLED88's Avatar
1965 20' Globetrotter
Jackson , California
I think I'm going to use a little acetone and some lego pieces to make a glue for the cracks, and then cover with Fibertech by Evercoat. It's a reinforced polyester body filler, which should have enough strenght to do what I need.
Thanks for the info
TIMK
Thanks in advance!
TAC CA-77
REDSLED88 is offline   Reply With Quote
1965 safari, 22', floor repair
Aft relief tube dripping through floor below sink kaiaua 1974 - 1979 Sovereign 5 02-21-2011 10:21 AM
The frame is ok ~ Patching the floor. LawChick Repairing/Replacing Floor &/or Frame 12 01-30-2011 02:39 PM
Replacing center roof vent in a '79 blickcd Roof Vents, Skylights & Fans 1 01-29-2011 04:58 PM
Fresh water tank relief valve "bumps" above floor? DanielB Fresh Water Systems 12 01-19-2011 06:00 PM
How to attaching the floor DanielB Repairing/Replacing Floor &/or Frame 17 01-09-2011 07:21 PM
