Old 04-13-2013, 11:59 AM   #1
GAStreamin's Avatar
2012 25' Flying Cloud
Moultrie , Georgia
Replacing Subfloor
We are in the middle of a full restoration of our 1978 Sovereign. It is our first time doing anything like this. We are new to forums and airstreams. Can the subfloor be replaced with 5/8" PVC boards? Would it be strong enough?
GAStreamin is offline   Reply With Quote
Old 04-13-2013, 12:11 PM   #2
1981 31' Excella II
New Market , Alabama
Do you have specs for this stuff?
Perry
Old 04-13-2013, 12:17 PM   #3
GAStreamin's Avatar
Moultrie , Georgia
It is cellular PVC board. It 5/8" thick. It comes in 18 ft pieces anywhere from 3/12" wide to 11 1/4" wide. It is used for exterior millwork on houses. We read an article with someone using Trex boards for an Airstream subfloor and this is similar.
Old 04-13-2013, 12:22 PM   #4
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Every product of this sort should have detailed specs on the manufacturer website. It may be difficult to find, but it should be there. If you can't find it, call the manufacturer and ask whether it can be used for a subfloor. Something used for walls is probably not strong enough for subfloor or would be too thick for using as a subfloor. Plywood, treated to prevent water damage, is probably the best solution and relatively easy to find. Big box stores may not carry it but can probably special order it. Go to the contractor's desk and ask for a discount.
Gene
Gene
Old 04-13-2013, 12:34 PM   #5
Images: 59
I've used this stuff to make shower grates and other items. I think it is a little too flexible to handle the spans between your frame members. If you use this, I would keep spans to 16", and I would rabbet & spline or tongue & groove adjoining boards to tie them together, otherwise the floor will be really bouncy.
markdoane is online now   Reply With Quote
Old 04-13-2013, 01:04 PM   #6
GAStreamin's Avatar
Moultrie , Georgia
I think I agree with you all! It probably is not strong enough. We will go with plywood, the safest route. Thanks for all the feedback!
Old 04-13-2013, 01:31 PM   #7
GAStreamin's Avatar
Moultrie , Georgia
Gene
What type plywood? Here in the south, we seem to only have pine plywood, which is heavier than fur. Should we get pressure treated plywood or plywood and them treat it with a sealer? I am just worried about getting something too heavy for 31' trailer.
Old 04-13-2013, 01:41 PM   #8
Master of Universe
Gene's Avatar
Trested wood is heavier than untreated, but I doubt the difference is significant. Specs should show weight of plywood. You can get pressure treated plywood or marine plywood. I don't know if marine plywood is pressure treated or sealed on the outside. You could seal it yourself, but it would be easier to buy already treated plywood. You'd have to seal each side, maybe more than once, and the edges especially. The labor is a time eater and messy.
People have used all sorts of sealers on subfloors. I used spar urethane on the top of the OEM subfloor when I replaced the flooring, but if I were replacing the subfloor, I'd look for something else or buy treated wood. One option is epoxy paint, but there are other sealants also.
Gene
Gene
Old 04-13-2013, 01:49 PM   #9
GAStreamin's Avatar
Moultrie , Georgia
Good to know! Thanks for all the help! If I can figure out how to do pics on here, I will post some when we finish.
Old 04-13-2013, 02:48 PM   #10
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Be careful with treated plywood. They will corrode normal fasteners that are not made to be used in contact with treated wood. Same goes for the frame and anything aluminum if you put treated plywood in direct contact with it (like the c-channel).
We used a good quality BCX plywood (exterior grade), and sealed the underside and ends with a couple of coats of oil based primer before laying the floor in the trailer. We also painted top with the same primer after we installed it.
Chris
Old 04-13-2013, 03:10 PM   #11
Master of Universe
Gene's Avatar
Chris is right. If you use stainless steel or some other fasteners, they cannot touch the aluminum or they may corrode it. Again, you have to check everything because of possible corrosion with differing metals. All of this gets more and more complicated as we learn more.
Gene
Gene
Old 04-13-2013, 05:30 PM   #12
GAStreamin's Avatar
Moultrie , Georgia
Yes, it does get more and more complicated! Good to know about treated wood! I am still not sure what to put down. We will keep thinking. Almost everything is out. We had new tires put on and axle inspected. It looks good. More inspections to come. One baby step at a time. Here are some pics.
ID:	183223   Click image for larger version
ID:	183225   Click image for larger version
Old 04-16-2013, 10:09 PM   #13
1969 27' Overlander
Boise , Idaho
Why are you replacing those floors? I don't see any significant damage, other htan some water stains. Are they rotting in ways or places not obvious in the photos? THey may not need replaced.
Jamespio is offline   Reply With Quote
Old 04-17-2013, 05:43 AM   #14
1981 31' Excella II
The biggest area for concern is the rear floor area which is the main structural attachment area for the shell. Small areas can be patched or treated with epoxy/fiberglass resin. Bleach and then some good deck and floor paint will solve smell and stain issues with the old floor.
Perry
Replacing windows in 1967 Overlander MAbdala Windows & Screens 12 05-15-2015 05:46 PM
Strange 'Vent' in Subfloor evanconklin Furnaces, Heaters, Fireplaces & Air Conditioning 6 01-09-2012 03:01 PM
Finally starting the project!! Subfloor question.. 61safari Repairing/Replacing Floor &/or Frame 18 11-21-2011 08:34 PM
