Old 10-29-2010, 08:06 PM   #1
1969 27' Overlander
Gold Hill , Or
replacing rotted floor sections on '69 Overlander
I am beginning the process of removing and replacing 3 sections of rotted flooring in my '69 Overlander. I keep reading about "C" channels which hold the flooring. As I have removed the first two sections, I have found nothing resembling a "C" channel. My floor seems to be attached to the frame with the elevator bolts, and to the shell via a more "U" shaped channel that is riveted to both the shell and the interior ribs. In the front of the trailer, are 4 or 5 heavy bolts that bolt thru the channel and into the frame. The plywood floor was screwed to the "U" channel. Am I missing something?
Jay
jayg is offline   Reply With Quote
Old 10-29-2010, 08:29 PM   #2
x
XXXX , XXXX
Jay it's called a C channel because the sides which have the shell and ribs riveted to are not as long as the bottom section of the channel which the floor is bolted down to the frame. If you look at it sideways it more resembles a C than a U.
wasagachris is offline   Reply With Quote
Old 10-29-2010, 08:34 PM   #3
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
C channel or U channel. Same thing.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 10-30-2010, 10:41 AM   #4
1969 27' Overlander
Gold Hill , Or
Thanks to both. I discovered that the bolts in the front of my trailer were thru the channel. and directly into the frame. I did not cut them but completey removed the rotted wood from around and behind them. They appear sound and relatively un-rusted. My plan was to simply notch around them as I replaced the flooring and maintain the rigidity of their hold on the front of my trailer. I am not removing the belly skin and am not finding more than surface rusting of the framing members so do not want to expand an already large project.
Old 10-30-2010, 11:11 AM   #5
Jay
The "C" channel becomes a "U" channel when it decides that your serious about the rebuilding process, then it makes a turn and stands at attention!!!!!
replace
Just got a '54 Cruiser- replacing floor tinman54 1950 - 1958 Cruiser 560 09-02-2016 05:52 AM
Replacing part of the Floor driftboatdan Repairing/Replacing Floor &/or Frame 0 02-08-2008 03:13 PM
Subfloor - Replacing Rotted Plywood traveller_nc Repairing/Replacing Floor &/or Frame 11 06-14-2007 10:00 PM
I removed the rotted floor today! chris's 67 Repairing/Replacing Floor &/or Frame 7 03-31-2007 12:39 PM
Replacing floor and frame.... Angel73 Repairing/Replacing Floor &/or Frame 0 06-02-2006 01:23 AM
