Old 06-22-2010, 03:51 PM   #1
15YearsAfter's Avatar
1970 27' Overlander
Nashville , Tennessee
Images: 8
Replacing fresh water tank support
Has anybody ever done or heard of replacing the 1 inch plywood under the fresh water tank with 1/8 inch thick aluminum sheet and one or two angle iron cross members to reduce weight. Any feedback ?????
15YearsAfter is offline   Reply With Quote
Old 06-22-2010, 04:16 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Is that enough weight reduction to make a significant difference?
My first take on your setup is that 1-inch plywood would provide a more uniform support for the tank than 1/8-inch aluminum.
Tom
Old 06-22-2010, 05:08 PM   #3
Maniacal Engineer
barts's Avatar
Menlo Park , California
Fir plywood weighs 32 pounds per cubic foot.... so that water tank support prob. weighs something on the order of 55*55*1/12/12/12*32 = 56 lbs....
Aluminum weighs 165.0 lbs per cubic foot, so 55*55*1/8/12/12/12*32 = 7lbs....
plus angle iron to support 50 gallons (8lbs/gal = 400 lbs of weight)....
When you're done, you may have managed to save 25 lbs. You will also have increased the likelihood of freezing the water tank in cold weather.
I'd winnow your packing list instead... it's lots cheaper not to take something
along to save 25 lbs.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 06-23-2010, 09:34 AM   #4
1970 27' Overlander
Images: 8
I am in the process of dismantling almost everything, the interior is gutted, the floor in the bath, steps/door area, and forward under gaucho are to be replaced. All new systems, plumbing with pex, flex duct for heat, some new cabinetry, etc... So since I have it torn apart, my goal is to reduce weight wherever I can as I put her back together yet still be safe, functional and enjoyable. As far as protection from the cold I could put polystyrene below and along side like the black tank. My wife and I do not plan to be in any extreme temperatures, although I know cold weather can sneak up on you. Thank you for the feedback so far, any more?
David
Fixing or Replacing Fresh Water Tank Utahgoldrup Fresh Water Systems 10 02-17-2014 09:19 PM
Gray Water Tank Instulation and Support Beams??? coairstream Waste Systems, Tanks & Totes 3 10-01-2009 02:54 PM
replacing fresh water drain valve HeadnOut Fresh Water Systems 5 05-13-2009 10:19 PM
Help with replacing pressurized fresh water tank glang58 Fresh Water Systems 14 08-31-2008 08:39 PM
replacing fresh water tubing? stglmyr Fresh Water Systems 4 04-06-2008 07:49 AM
