Old 04-15-2004, 12:25 PM   #1
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Replacement Insulation
I am in the middle of replacing all of my Black/Grey tank plumbing under the trailer. Well the fiberglass insulation looks pretty bad and I was thinking how it might be an improvement to replace it with "Spray in Polyurethane Foam".
I was wondering if anyone has any experience with this change. I could get an R value of about 6.7 per inch of foam. This would be loads better than the scanty 2" glass batting. I was also thinking that it would improve the strength of the ABS plumbing, sort of encapsulate it and keep it from rattling on dirt roads.
Thoughts?
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 04-15-2004, 12:38 PM   #2
87MH's Avatar
1978 31' Sovereign
Images: 292
Gary:
It'd be a booger to tear out should you ever need to access the plumbing lines it (the foam) would surround.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 04-15-2004, 12:45 PM   #3
1964 26' Overlander
1977 25' Tradewind
I hadn't thought of that, maybe spray it just as thick as 1/4 to 1/2 of the pipe in thickness. That would give me about 2" to 3" or about R-13 to 18.
Peace
Gary
Old 04-15-2004, 12:50 PM   #4
LOST , Hawaii
Dennis
I agree with a lot of what you say but disagree this time. I inuslated all my walls with spray foam. All the small openings were covered with masking tape, the wiring and vents were plumbing vents were sprayed. Removal is as simple as cutting with a sharp serrated knife, the insulation sticks to the aluminum but peels off as a plug. I would do it again.
John
74Argosy24MH is offline   Reply With Quote
Old 04-15-2004, 12:50 PM   #5
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I'm wondering how the original batts were held in place?? or were they at all?
also wondering if its worth the effort for a "fair-weather" camper. how about those hermetically sealed fiberglass batts? so you don't git all itchy, and stuff? don't know what the r-value is, though...I seem to remember "R-11" being printed on the side of some 2" rigid foam boards that I have in my basement (different project ).
might be doing similar work this season. take pictures!!
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 04-15-2004, 01:51 PM   #6
1964 26' Overlander
1977 25' Tradewind
Chuck
The fiberglass was a bare batt. It was one piece being held in place by just the pipes. No stick em or tape, no nothing. I thought it was a pretty cheesy way of doing it, it crushed the batt to less than 1/2" thick under the pipes.
I looked at the web site for the spray foam and they listed R 6.7 per inch thickness.
Good ideaon the pics, I'll take some pictures before I seal it back up.
Peace
Gary
Old 04-15-2004, 02:18 PM   #7
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
so when you drop the belly pan, be prepared for this stuff to drop right out in your face with it, eh?
does sound "cheesy". and the R-value only holds true if the stuff is allowed to fluff to its intended thickness. doesn't apply if you squish it up. so perhaps I have an indirect answer to my question: it ain't doing anything, except perhaps providing the mice w/ cozy accomidations.
I guess there's not really much place for it to go, though...only needs to stay in place long enough for them to re-attach the belly pan.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 04-15-2004, 03:30 PM   #8
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 118
I just dropped the belly pan in my 72' and the insulation was fairly thin (about 3"), in very good shape, and sandwiched between the beams and the plywood which is what was holding it in. Surprisingly enough, no signs of rodents, a spider or two, and no snake skins.
My 77 Sovereign Renovation
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
Sneakinup is offline   Reply With Quote
Old 04-15-2004, 05:20 PM   #9
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Images: 90
"Stealth Post"This is really Gary. I found 4 Wasp nests and a lot of Black Widow egg sacs. All clean now. Ya, the insulation they used is for the birds or Wasps or what ever. I'm going to use the spray foam to do away with all that.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 04-15-2004, 06:15 PM   #10
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
How well does foam hold/attract moisture? The bottom area of the trailer must "breathe" otherwise rot sets in the floor. It is for that reason I just take the insulation out and leave it out. To me its just a big sponge - I've also been told you don't want to tight seal the belly - it must breathe.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 04-15-2004, 08:10 PM   #11
till's Avatar
Lisle , Illinois
Images: 108
Thinking out loud,
Wouldn't the vibration from towing the trailer just rattle the spray foam to dust?? Over time that is...... like a few years/ thousnad or more miles of towing
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 04-15-2004, 08:29 PM   #12
Originally Posted by till
Thinking out loud,
Several people on these forums have mentioned replacing the insulation in the walls with foam, and I had always feared the same problem. However, I recently saw an Avion in a salvage yard that had foam insulation in the walls. I was impressed by two things: 1) How well the foam had remained intact; and 2) How many voids it had in it.
There may be more movement underneath, however. Airstream frames are rather "springy".
Mark
Old 04-15-2004, 08:32 PM   #13
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
I think Andy from Inland RV said that Airstream tried the Foam insulation but had trouble with it. I know that the GMC Motorhomes used it without much trouble, and now with this Avion info. I wonder what was the main issue? John, I know you used it. it will be interesting to see how it holds up over time.
Who knows, maybe they tried an early version of it?
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 04-15-2004, 10:11 PM   #14
jjonesnc's Avatar
Cary , North Carolina
Images: 8
Send a message via Yahoo to jjonesnc
Whats the name of the spray in foam stuff? had not thought of that but sounds like a great idea......
jjonesnc is offline   Reply With Quote
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Insulation used in Classic Limited series - 2004? flyfisher 2001 - 2005 Classic 20 11-08-2004 03:38 PM
Under floor insulation Rick Alston Repairing/Replacing Floor &/or Frame 18 01-26-2004 08:02 PM
Glass windows; insulation smallfry Windows & Screens 5 01-10-2003 05:15 PM
