Old 06-04-2011, 10:44 AM   #1
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Replace Subfloor without removing shell?
This may have been answered already, but I can't seem to find it. My newest AS acquisition (1976 Argosy 26) is suffering from a rotted floor in the bath and the smell from the front flooring area is too much to bear. Is it possible to replace the floor without removing the shell? If so, how to go about it?
Phrunes is offline   Reply With Quote
Old 06-04-2011, 10:53 AM   #2
x
XXXX , XXXX
it's actually very easy to replace the front and rear sheet of the sub flooring. For those sheets the shell and the C channel it is bolted to sits on top of the floor. That will be for the end cap sections of the shell only. The straight sections along each side have the channel wrapped around the edge of the floor.
You will need to remove the inner skins(walls) to get at the bolts that hold the C channel to the frame. The belly pan will also need to be opened up to get access to the bottom of those bolts.
Once the bolts are removed and the screws holding down the floor you can just slide the section of floor out and replace it with new. Then rebolt & screw, reinstall the inner skins and it's done.
wasagachris is offline   Reply With Quote
Old 06-04-2011, 10:58 AM   #3
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Chris,
Thanks! Super fast reply and complete as always.
Thanks!!
Matt
Old 06-04-2011, 11:14 AM   #4
x
XXXX , XXXX
You're welcome Matt.
When you remove the main holddown bolts(2 front & especially 2 rear) the frame will drop away from the shell. Once you are reinstalling them make sure the frame is supported level both side to side and front to back other wise you will lock in the twist or sag to the frame against the shell.
When I cut my rear ones loose the frame dropped 3 or 4 inches and scared the c**p out of me.
If the bolts are really rusted up and they will be, just grip them with vise grips and bend them back and forth to fatigue the metal and they will snap off. It's much easier than trying to grind the heads off or trying to sawzall them off. Ther will be a few small sheet metal screws in the channel. They are used to hold the channel in place against the floor, either chisel or grind the heads off as they will too be rusted beyond recognition.
Old 06-04-2011, 11:39 AM   #5
1985 31' Excella
Fresno , Texas
If you block and level the frame before you began work then you will prevent a frame drop and also assure that the inner skin holes will line back up when you put the panels back in. I was told to block in at least 8 places.
Wsmith is offline   Reply With Quote
Old 06-04-2011, 01:35 PM   #6
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We replaced the entire sub-floor in our '56 w/o removing the shell. You can see the entire resto process in our "It's a Girl!!!" thread.
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 05-07-2012, 07:15 AM   #7
Tallahassee , Florida
Argosy Front and Rear Sheets
I have found my 75 Argosy 24 also has the aluminum extrusion that captures the plywood along the straight portion of the rear (between the curved parts). Mine uses 5/8 plywood and the slot that captures the plywood also has an additional web that will necessitate a saw cut to the edge of the plywood. This means I am digging old rotten wood out of two 1/4 inch slots.
Has anyone else found this in Argosy models?
Overall, my floor is pretty good, and I only need to replace about 12 inches across the back. Too bad we cannot used treated plywood, but I learned from a boat forum that treated wood and aluminum are not compatible.
alfaguy is offline   Reply With Quote
Old 05-07-2012, 09:52 AM   #8
1971 29' Ambassador
guyton , Georgia
air chiels work good jus be real carefu
r.swanson is offline   Reply With Quote
Old 05-07-2012, 11:11 AM   #9
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
There is another active thread that touches on some of the same questions:
http://www.airforums.com/forums/f36/floor-replacement-off-with-the-shell-or-the-underbelly-89975.html
good luck!
Old 06-12-2018, 05:07 PM   #10
Winter Park , FL
Did you just replace the 12 inches? How did it go? I have a very small area by my rear hatch that I want to replace. I am not removing belly pan or shell or interior. It's such a small area that it wouldn't be worth the effort. Can you further explain your process? Thank yoU!
KelseyWander is offline   Reply With Quote
Old 08-21-2019, 07:55 AM   #11
1976 Argosy 28
Buford , Georgia
I am about to take this on with my 76 28' Argosy in the front and rear. I will be replacing both sections complete back to the first joint (about 4').
I already have the old stuff (or what was left) torn out and most of the screws out (a few will need some help).
John
strangepod is offline   Reply With Quote
Shell removal confusion P&K Repairing/Replacing Floor &/or Frame 6 05-21-2011 06:32 PM
Dry fitting shell..shims needed? Becky B. Belly Pans & Banana Wraps 2 05-17-2011 05:44 AM
Shell on? Shell off? Althea68 Repairing/Replacing Floor &/or Frame 55 04-01-2011 09:35 PM
75' Tradewind replace tanks? Breadbug Fresh Water Systems 7 03-06-2011 10:11 AM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 06:20 AM
