Old 04-02-2011, 09:34 AM   #1
1967 20' Globetrotter
Cadillac , Michigan
Repair services
My daughter has a 1967 Airstream located in Cadillac, Mi. We plan to use it on a long distance trip this summer and would like some repairs made to the unit.
When it was purchased, the frame behind the wheels was cracked/broken. This has been repaired but I am concerned about other parts of the frame. Is it possible for the metal on the bottom to be dropped so as to examine and reinforce the frame?
There also is aluminum that is worn though inside the rear access door that needs to be replaced/repaired to help mouse proof the trailer.
We would also be interested in having the trailer polished as the exterior is in excellent condition.
Do you have any suggestions for repair facilities that might do this work?
Keith
kjohnsonmi is offline   Reply With Quote
Old 04-02-2011, 09:45 AM   #2
2010 27' FB International
La Crescent , Minnesota
Woodland Travel Center in Grand Rapids would be abe to help you.
Jay
mjayjensen is offline   Reply With Quote
Old 04-02-2011, 10:58 AM   #3
Keith
Keith.
Two things cause the frame failure.
1. Unbalanced running gear.
2. Bad axle/axles.
Old 04-02-2011, 12:38 PM   #4
1962 16' Bambi
2001 31' Limited
1985 29' Sovereign
Jenison , Michigan
Images: 8
Woodland Travel Center (Grand Rapids,MI AS dealer)........ does SUPER work and is always FAIR and HONEST. They are only about 75 miles from you.
62bam is offline   Reply With Quote
frame, polish, repair
Dash Repair shepherd57 Argosy Motorhomes 2 06-22-2013 07:48 AM
Repair to Interior Door Panels of Dometic M 70b 69AirDream Refrigerators 13 04-01-2011 08:15 AM
Pacific Northwest Repair or Restoration TGK General Repair Forum 11 03-30-2011 01:24 AM
Cost to repair 02 Bambi & approx. value as is au_ee Ribs, Skins & Rivets 0 03-21-2011 05:02 PM
Removing underbelly to clean, repair water lines Airdaddy Ribs, Skins & Rivets 2 02-17-2011 08:30 PM
