The repairs needed on your trailer will be very expensive if you pay someone to do it and that is assuming that they do it correctly. There a lot of man hours need to do the work. If you have time , fixing the trailer isn't rocket science. Like Wasagachris said, basic tools are all that is needed. What you need to know to do it is available with some searching here on the forums as it has been covered many times by many folks. If you do chose to have it done, make absolutely sure that you understand what has to be done and how it needs to be done so you can monitor the progress and give advise if the repair person has not done an Airstream before. Good luck.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
