Old 02-11-2005, 07:34 PM   #1
Profile:
Removing the body/shell
Can someone explain how to remove the body/shell? Thanks
Will
William8979 is offline   Reply With Quote
Old 02-11-2005, 09:23 PM   #2
Stefrobrts's Avatar
Profile:  1968 17' Caravel
Battle Ground , Washington
Airstream Registry
Do a search for shell off floor replacements. There's been a bunch of great step by step threads.
I opted to leave the shell on, but my floor and frame damage was not very extensive.
Stephanie
Stefrobrts is online now   Reply With Quote
Old 02-12-2005, 01:29 PM   #3
Profile:  1973 31' Sovereign
Portland , Oregon
You may not need to take the shell off...
Will,
If you can be more specific as to what you are wanting to do it migh help. I for one feel that most floor repairs can be done without taking the shell off of the frame unless there is really significant frame damage that can not be repaired without taking the frame entirely out. Check out the following threads for a lot of information on what I did and things that others did too.
http://www.airforums.com/forum...0&page=1&pp=20 An alternative to plywood
http://www.airforums.com/forum...ad.php?t=13732 Some discussion about shell on techniques.
"Shell Off vs Shell On" several notes especially my post #74
"HELP!!! On a tight schedule, need to replace..." my post #26
Hope this all helps,
Malcolm
malconium is offline   Reply With Quote
removing Dometic Refrigerator smily Refrigerators 14 10-29-2007 04:01 PM
Removing the body shell and installing new floor completely - any one done this? williamhenshall Repairing/Replacing Floor &/or Frame 11 03-13-2006 11:21 AM
Removing wallpaper from 76 tradewind Rennegarbe1 Upholstery, Blinds, Walls & Interior Finishes 4 02-05-2003 04:52 AM
removing electric jack CHRIS CANNON Our Community 0 09-30-2002 06:51 PM
Removing Vulkem JrnymnJay Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 05-03-2002 11:49 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
