Old 04-03-2009, 02:34 PM   #15
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
My black tank is on top of the floor, directly under the toilet.
What I'm considering doing is doubling up along the long edge, and then obviously the splice. In addition I'm thinking about biscuit joining wherever possible.
Then again, the joint needs strenght, but it's not like it's going airborne ( I hope)
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is offline   Reply With Quote
Old 04-03-2009, 04:24 PM   #16
1957 22' Flying Cloud
Odessa , Washington
Talking subfloor de-construction
Originally Posted by SilverHoot View Post
I'm sure this has been asked before but I was unable to find it with search function. I see where some have set their (Skil type) saw to cut at the depth of the plywood then proceed to make cuts around area to be replaced. My question is what do you do for the areas next to the wall? My saw will only get to within about 6 inches of the wall then there is another 2 inches under the wall to deal with. Thanks.
Hi SilverHoot,
Are we having fun yet? I just went thru this stage a few weeks ago. You can get pretty close w/ a reciprocating saw, but as stated elsewhere you have to be very attentive or you might saw into something you didn't intend to. (No big deal, just had to repair weld a few small cuts in the frame.) For the final act use a fairly large bit (1/4 - 3/8) and drill zillions of holes into the plywood. You can even drill at an angle into the area under the c-channel. Then go at it with a big ol' screwdriver an' hammer. Mine was pretty rotten so it came out in big chuncks. As for those rusty bolts and screws an angle grinder w/ a cut-off blade is the way to go.
John Whyte
Odessa, WA
(the geographic center of nowhere)
New to this forum, RV'ing & Airstreams
Old Nuke is offline   Reply With Quote
Old 04-03-2009, 04:37 PM   #17
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Got the back piece out!
Once I removed the hidden rivets (they were at about 6-inch intervals), removed rearmost the belly pan, dremel cut-off carriage bolts and removed U-channel I tried prying at the joint and it would not hardly budge. Found that it was joined and cleated with another piece of plywood at the joint. So I lifted and twisted and cussed and pried and ripped it outta there. Cannot believe how wobbly the WHOLE shell is with just that rear portion removed. Going to get some bracing on it as I work towards the front.
SilverHoot is offline   Reply With Quote
Old 04-03-2009, 04:39 PM   #18
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Here's a early Safari with the same rot as yours
http://www.airforums.com/forums/f36/...air-38434.html
Old 04-03-2009, 05:07 PM   #19
Rivet Poor
BNC4K's Avatar
1958 22' Caravanner
1968 26' Overlander
Mount Solon , Virginia
Send a message via Yahoo to BNC4K
Kip, did you have the interior skins removed to do this?
Carol
Keepin it together one rivet at a time
BNC4K is offline   Reply With Quote
Old 04-03-2009, 05:27 PM   #20
Aerowood's Avatar
Arvada , Colorado
Carol
Yes, it was completly gutted.
Kip
Removing vent pipe without cutting? bennyg Ribs, Skins & Rivets 0 07-05-2011 04:42 PM
Need help with removing water heater walker77 Water Heaters, Filters & Pumps 2 04-15-2011 06:01 PM
Removing shower valve in 74 Argosy 24' twilder Sinks, Showers & Toilets 2 04-02-2011 08:28 PM
Removing sealant around my vent pipes on a1989 345LE Motorhome. maxr Classic Motorhomes 0 03-22-2011 08:29 PM
Need help removing rivets. Breadbug Windows & Screens 16 01-19-2011 08:11 PM
