Old 05-16-2010, 10:04 PM   #1
2008 28' International CCD
L.G. , Virginia
Question Removing fiberglass insulation adhesive???
We are in the processing of removing our fiberglass insulation and replacing it with aluminum clad Prodex insulation on a late model (2008) airstream.
The fiberglass is mostly out leaving the adhesive and some bonded strands of fiberglass. We want to to remove the adhesive leaving clean aluminum.
What experience has anyone had removing the adhesive? Would acetone work? Any other solvents that might be better?
Thank you for your suggestions!
wrajr is offline   Reply With Quote
Old 06-01-2010, 11:17 PM   #2
L.G. , Virginia
Airstream fiberglass adhesive
I found that the material used by airstream to adhere the fiberglass is called Bondmaster 40-0880 made by National Adhesive. It is based on SB Rubber.
I found that the solvent for rubber is Turpentine and Naphtha. Has anyone tried this for removing the adhesive?
Old 06-07-2010, 10:35 PM   #3
1967 24' Tradewind
1979 25' Tradewind
thermopolis , Wyoming
Try some aerosol gasket remover from an auto parts store. Be careful this stuff is really strong and even the smallest over spray on your skin will burn. This stuff will even take off silicone!
Let the forum know if it works.
cheers, John
amoretti is offline   Reply With Quote
Old 06-09-2010, 02:01 PM   #4
Peasleeville , New York
insulation removal
I have not tried to remove the adhesive, and I am not certain why you would feel like it was necessary? I have a '74 31' international that is gutted. I found that a shop vac with an upolstry attachment was amazing to get the smaller fibers out.
mbattin is offline   Reply With Quote
adhesive, aluminum, fiberglass, removal
Insulation in the walls -- adhesive or no adhesive? wrajr Repairing/Replacing Floor &/or Frame 8 04-27-2010 09:08 PM
Removing insulation travelbead Upholstery, Blinds, Walls & Interior Finishes 0 04-22-2010 11:11 AM
Which flooring adhesive? Anniedog Floor Finishes 1 09-18-2009 05:23 AM
Vinyl Floor Adhesive kevino Floor Finishes 5 05-11-2007 07:34 AM
Rubrail Adhesive and Repair Shepstream Clearcoat, Exterior Paint & Trim 3 08-09-2004 11:01 AM
