Old 08-20-2012, 07:40 PM   #1
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
Removing elevator bolts- this worked for me
Working on the Bambi II, I got a medium sized hole saw and my drill. I drilled a hole around each elevator bolt head (with the pilot bit off center) about 1/4" deep. Then I chiseled out the circle of wood. This gave me greater access to the elevator bolt heads. I locked a vise grip on each one and wiggled it until it broke off, then tapped the remaining threads into the belly pan. We'll find those later. This procedure worked quite well.
ID:	166314   Click image for larger version
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 04-26-2016, 03:56 PM   #2
KEIZER's Avatar
1980 31' Excella II
1973 31' Sovereign
Noonan , New Brunswick
This is just what I needed thanks. now to go find my hole saw kit. ��
WBCCI #6722
Ham Radio VE9NKD
KEIZER is offline   Reply With Quote
Old 04-26-2016, 04:20 PM   #3
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I cut around them with a plunge cutting blade on a Harbor Freight multi tool then cut the bolts of with an electric cutoff tool.
When replacing the floor I used self threading floor bolts which worked out well.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
