Old 07-07-2015, 03:45 PM   #1
AlumaTurtle's Avatar
Olean , Missouri
Removing Belly Pan from Overlander
I am replacing part of the flooring in my 72 27' Overlander. Rear axle is out and I want to Por 15 the frame while I am there. Is there a way to remove the rear part of the belly with out cutting across, and then splicing to replace? Don't want to cut and splice if I don't have too.
Dave
AA0AE
AlumaTurtle is offline   Reply With Quote
Old 07-08-2015, 08:19 AM   #2
chilipepper's Avatar
1971 27' Overlander
Dickinson , North Dakota
I removed mine last spring and replaced the last 4 feet of flooring as well. I removed the belly pan all the way to the fresh tank where the sheet ends. I have heard of people that take the back down and then roll it back under the trailer towards the front to get it out of your way. It will roll fairly easily when you get the blind rivets out.
I just decided to make it a bigger project and since I had it out I added grey tanks and re-insulated as well as Por15 all the way to the fresh tank. Good Luck!
Ryan Jilek
WBCCI 7165 | TAC ND-3
Ms. Streamy - 1971 Overlander Restoration Blog
chilipepper is offline   Reply With Quote
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 08:43 PM
Removing Belly Pan garp Belly Pans & Banana Wraps 5 07-06-2016 12:48 PM
Removing Rear Belly Pan kneal Belly Pans & Banana Wraps 3 02-13-2007 09:00 AM
Removing the belly pan Flyboy Belly Pans & Banana Wraps 9 11-15-2005 08:11 PM
removing corroded belly pan screws Cruiser Belly Pans & Banana Wraps 2 09-14-2003 12:17 PM
