Old 08-18-2011, 08:27 PM   #15
Tool Hoarder
West , California
Looks like years of leaky windows vents and openings. The sub floor probablly should be replaced. Do it right drop the pan lift the shell strip and paint frame replace sub floor and belly then button her up. Its not that hard.
marzboy is offline   Reply With Quote
Old 08-18-2011, 09:16 PM   #16
1976 31' Sovereign
Pittsburgh , Pennsylvania
Thanks for the advice. Is there a quick fix for the moment? I can't really do much until next spring. I won't move it or do much more than sleep in it.
I figure I can replace a few pieces of plywood but I can't seem to figure out the c channels.
Your thoughts?
Thanks!
Mikal
gronlampa is offline   Reply With Quote
Old 08-20-2011, 08:27 AM   #17
Tool Hoarder
West , California
looks like water damage from leaky windows or vents.
How to remove swirls?anyone can tell me what is the best technique for removing the m Astriking Cleaning, Stripping & Polishing 17 08-08-2011 08:07 PM
RemovAll 220 - will it remove old caulk? malconium Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 06-21-2011 08:26 PM
Floor/frame separation fix - section or all at once? GlobeTrottin Repairing/Replacing Floor &/or Frame 11 05-12-2011 07:21 PM
How to remove slip hub / flange 1970 3/4 bath silversafari Waste Systems, Tanks & Totes 2 02-27-2011 07:40 AM
