Old 04-28-2007, 08:20 PM   #1
1989 34' Excella
laurens , South Carolina
Removal of floor
In our '89 Excella 34' we decided to change our queen to twins. Once the bed was removed, then the carpet -- surprise. There has been a leak from who knows where and most of the floor was rotted. We are attempting to remove the floor -- Does anyone have any ideas on how to best remove the wood flooring from under the walls? Any help would be greatly appreciated!!
brown bear is offline   Reply With Quote
Old 04-28-2007, 10:34 PM   #2
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
Can of Worms, go fishing!
There are lots in the same boat. Me too.
A thorough analysis is called for. Not to be too melodramatic but on mine a hole in the floor led to the discovery that my frame was ruined.
I hope that all you need is a patch but there are excellent threads on floor patches and replacement.
Under search try 'floor repair' and follow the threads.
I still enjoy the Airstream very much.
R
fastrob is offline   Reply With Quote
Old 04-29-2007, 05:18 AM   #3
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
For the floor replacements we have, we pulled everything out to get at the bad wood. It's allot of work but there is no question in the end you got it all...
Check this out
Bathroom Removal
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 04-29-2007, 08:42 AM   #4
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
We are replacing floors & floor sections on a regular basis. You will need to remove the inner lower wall sections & the bellypan in the effected area in order to gain access to the bolts holding the lower "C" channel in the wall to the chassis. We have discussed this topic several times on the Vintage Airstream Podcast theVAP - The Vintage Airstream Podcast - Home . Good luck with your repairs,
Colin
Colin H is offline   Reply With Quote
Removing the body shell and installing new floor completely - any one done this? williamhenshall Repairing/Replacing Floor &/or Frame 11 03-13-2006 12:21 PM
Question re new floor fitting on our 1958 Traveller williamhenshall Repairing/Replacing Floor &/or Frame 9 06-30-2004 04:08 PM
When lacking a floor to make a template... JrnymnJay Repairing/Replacing Floor &/or Frame 6 11-30-2002 07:28 PM
Front floor area and rebuilding dresser jeanarlene 1969 - 1973 Safari 10 09-05-2002 12:11 PM
Total floor replace 74Argosy24MH Repairing/Replacing Floor &/or Frame 1 06-27-2002 05:05 PM
