Old 02-24-2007, 06:08 PM   #1
1967 24' Tradewind
gilbert , South Carolina
Reinforcement plate for 76 31ft. sovereign?
I have seen many posts from people about the reinforcement plate, to keep the rear end of the trailer from sagging. I have removed the belly pan on my sovereign and I don't think that one has been installed, because I see the round punch marks in the frame as I saw mentioned by someone. If someone has a picture of this plate I would like to see one. Also I would like to say that my camper is a center bath model and I can detect no sag or cracking in the frame. My question also is whether or not I need to install this plate on a center bath model or is this problem more common on rear bath models. Thanks for anyones help.
chris's 67 is offline   Reply With Quote
Old 02-24-2007, 07:07 PM   #2
Silver Mist
LI Pets's Avatar
Riverhead , New York
Take a piece of string along the belt moulding from front to back see if it's straight.
You can jump on the rear bumper also to get kind of a test??
With a center bath you shouldn't need and support IMO.
Old 02-24-2007, 08:38 PM   #3
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 220
Chris,
The main thing I'd be looking for is the condition of the frame and the floor. While a rear bath may be more susceptible to rear end separation due to multiple sources of water damage (plumbing), a rear bedroom can have problems as well if the rear seal between the beltline and rear bumper fails. (I found out about that first hand with my '73 Sovereign centerbath. The last frame crossmember was nearly gone from rust.)
The reinforcement plate just gives added strength the the fastening point of the shell to the frame. (A solid floor and rear channel support should be sufficient to hold the point together.)
I think the reinforcement plate was just extra protection.
But none of these things will prevent problems ultimately if axles are worn (rough ride, bottoming out) and running gear is out of balance (excessive vibration, accentuated at the end of the "see-saw").
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
'85 Sovereign 25' j54mark 1984 - 1989 Sovereign 13 11-07-2013 11:24 AM
'78 Sovereign Awning Joan D'Andrea Awnings 6 01-03-2006 07:34 AM
dull roof on 1986 31' sovereign Daryl Miron Roof 12 07-25-2005 12:37 AM
TV Connection Plate winner Audio, Video & TV 10 06-16-2002 06:00 PM
Help with Ancient Sovereign patti 1955 - 1959 Sovereign 2 06-06-2002 02:23 PM
