Old 08-13-2014, 07:13 AM   #1
truxpin's Avatar
2001 34' Limited
Tucson , Arizona
Refinishing A-Frame, needing Paint color
OK, I give up on the search function on this forum.... Maybe I'm doing something wrong, but 5000 results searching "frame paint color", and 98% of those have nothing to do with what I'm looking for.
I'm having a fellow come out and soda blast the front a-frame of out '01 Limited. I've pulled off all the Hensley attachments, emergency brake, gas bottles, etc....
So we should be starting fresh with a nice metal surface.
I'd like to come close to matching the original color (some shade of dark grey) with a nice oil based or urethane paint. anyone know of either a source or possibly a color code to reference?
2013 Ram Power Wagon 2500 4X4 5.7 Hemi
2001 Airstream '34 Limited
Hensley Arrow
Fulltime in 2013 and LOVING it !!
truxpin is offline   Reply With Quote
Old 08-13-2014, 07:24 AM   #2
truxpin's Avatar
2001 34' Limited
Tucson , Arizona
I guess I should have just used Google search instead. I just searched google with "2001 Airstream A frame paint color" and it pulled up a dozen posts from Air Forums, among others as well. :-)
Hensley Arrow
Old 08-13-2014, 07:27 AM   #3
Paddledipper's Avatar
1977 27' Overlander
1996 34' Excella
Florida Panhandle , Florida
I have found the same thing! I thought it was my user error but your post just made me feel much better. Maybe someone has some pointers.
The Evans' Family
Florida Panhandle
1977 Overlander / 27' ~ The Attitude Adjuster
1997 Airstream Excella / 34' ~ The Sane Asylum
Paddledipper is offline   Reply With Quote
Old 08-13-2014, 07:28 AM   #4
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
I had my 1976 Sovereign polished and the A frame and lower body roll painted with the same color paint that they use in the newer Airstream's at Oasis RV http://www.oasisrv.com/. You may be able to check with them on the paint.
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 08-13-2014, 07:32 AM   #5
1967 26' Overlander
Bugtussel , Oklahoma
Can't help with the paint but I share the same experience with the search function on this forum.
1967 Overlander International 26ft
2006 Porsche Cayenne Turbo S 520hp 530ft-lbs torque 7700lb towing capacity
mikextr is offline   Reply With Quote
Old 08-13-2014, 07:39 AM   #6
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
If you have a removable piece of the desired color take it to any auto paint shop / body shop and they can custom mix you a single stage paint to match. Auto paint ain't cheap but you can get a liter or so and it will last awhile for touching up.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 08-13-2014, 07:57 AM   #7
dznf0g's Avatar
Oswego , Illinois
Here's what I used. It is a bit more of a "blue" gray than the AS gray. The AS color actually looks to be a "green" gray when next to the a-frame. But this is about as close as you are going to get IMO.
Color Codes - Dupont B8270 Cross-Reference
Results here:
http://www.airforums.com/forums/f44/...gue-95502.html
-Rich-
2005 Airstream Rear Frame & Tongue Paint Color Mudflap Exterior Restoration Forum 0 10-12-2012 09:15 AM
Color temperature and color rendition index of fluorescent tubes Jammer Lights - Interior & Exterior 3 08-16-2010 08:29 PM
Refinishing the rear light frame on an '86 Airstream ckeysor Clearcoat, Exterior Paint & Trim 1 01-10-2009 12:16 PM
Best color paint for '67 frame, bumper, tongue? Stella Clearcoat, Exterior Paint & Trim 12 02-17-2008 08:40 PM
Frame Color Paint maerix Repairing/Replacing Floor &/or Frame 5 07-19-2006 12:09 PM
