Old 05-07-2014, 09:43 AM   #1
1974 31' Excella 500
Roy , Washington
Reenforcing Wheel Wells
Hi All -
'74 - 31ft Excella... The outer skin around the wheel wells is loose, wet and in need of some help. I have gutted the interior, removed the beige wheel wells and found the insulation therein soaked. So yes, re-caulking windows, seams, roof... etc. But there is a real problem around the wheel wells. The outer skin seems to be floating free in the breeze, not connected to anything remotely resembling frame members around the well.
Is there a frame member across the top edge of the wheel well? Or is the outer skin supposed to be attached directly to the black inner, plastic wheel well? Has anyone added an additional cross member there?
Open to any and all recommendations!
Cheers!
Truck
truckirwin is offline   Reply With Quote
Old 05-07-2014, 12:41 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
The outer skin should be pop riveted directly to the black plastic wheel well. There isn't a frame member across the upper edge of the wheel well skin.
good luck!
New tanks around wheel wells? truckasaurus Waste Systems, Tanks & Totes 0 10-12-2008 05:52 PM
sealing seams in the wheel wells.. safari25-05 Wheel Wells 6 01-16-2007 03:38 PM
Wheel wells question cameront120 Roof 4 06-11-2006 10:41 PM
Leaky wheel wells TomW Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 10-25-2005 01:00 PM
Plastic Wheel Wells Dennis Interior Restoration Forum 14 01-17-2003 12:05 AM
