Old 11-28-2006, 04:43 PM   #1
acton
Recommended floor material
Im doing a floor replacement on a 63 tradewind and have seen different recommendations as far as what to use for replacing the floor. Ive seen some suggest marine grade plywood and others used a type of Poly flooring.
I cant any of the threads but my question is other than marine grade plywood what are the best ways to go, also what can I apply on the edge for a moisture barrier.
Thanks in advance.
Mitch
durans54 is offline   Reply With Quote
Old 11-28-2006, 05:53 PM   #2
If you're going to replace the entire floor, I would recommend a product called Advantech. It's waterproof and has a 50 year guarantee. It's available at Lowe's or other lumber suppliers. It's 3/4 inch thick, looks similar to OSB but is far superior. Due to the housing slump the price has dropped to around $20.00 for a 4x8 sheet.
mjbord is offline   Reply With Quote
Old 11-28-2006, 06:03 PM   #3
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
When I purchased a shed for my yard, as it was being set up I noticed that the floor appeard to be OSB. I questioned the installers as I recalled when I made the purchase, the models were plywood floors. They told me they were having a lot of problems with the plywood delaminating and this was a new product called Advantech which seemed to be successful. I am always bringing in wet equipment, gas and oil leaks. The floor has been very solid and shows no signs of deterioration. This is in a shed, not an Airstream. I believe this material is very stable. I'm sure you'll get all kinds of recommendations until your head is spinning. Other have done the research and can tell you first hand service proven performance. Give us an update on the direction you choose. Good luck on you project, floors are a great experience. You'll learn it's the first component installed after the frame is built.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 11-28-2006, 06:34 PM   #4
acton
Thanks for the tips guys, I will look into that product and let you know which way I go
Old 11-28-2006, 06:35 PM   #5
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Marine grade is a waste of money in this install, it has the same glue as exterior.
THe difference is the innner plys have no voids-which in needed on boats.
'77 Sovereign Intl 31' CB
Old 11-28-2006, 06:52 PM   #6
urbanfood's Avatar
1956 22' Flying Cloud
Venice , California
i'm getting ready to do replace my floor too. the advantech stuff sounds interesting. i'll be curious to find out what others have to say.
here's an old post with some info:
http://www.airforums.com/forum...ight=advantech
david
*by asking the above question,
i verify that i have already used
the search feature to the best of my ability...
urbanfood is offline   Reply With Quote
Old 11-28-2006, 07:56 PM   #7
CanoeStream's Avatar
St. Cloud , Minnesota
If you go 3/4" I fear you'd have to do a shell off. The original material was about 1/2" and very little more. I used some nearly solid core 19/32" underlayment on my Argo -- sealed all edges with Rot Doctor. But it was a tight fit. 24/32" would be too much.
5 meter Langford Nahanni
Old 11-28-2006, 08:05 PM   #8
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
I used 1/4" luan as an underlayment screwed and glued then covered with self stick tile and later with engineered wood flooring. It works great and have had no problems with either flooring. I personally like the engineered wood look. It was a easy project to do well within the ability of most weekend warriors.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 11-28-2006, 08:05 PM   #9
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
You could use a router to cut down the edge to fit?
I suggest getting 1/2" exterior ply, it did work for the past 30-40 years.
The one thing I would do (and did) is coat the wood with fiberglass resin it will last forever.
Old 11-28-2006, 09:50 PM   #10
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Is this advantech product structurally up to the job? It may be better in terms of de-lamination. Along with the walls and frame, the floor is a major part of your structural integrity. I would go for the product that has the structural properties, and then add a sealer/resin or something if you are concerned with moisture.
Dave
Fyrzowt is offline   Reply With Quote
Old 11-29-2006, 03:36 PM   #11
acton
checked out lowes today for this advantech but they dont seem to know what Im talking about. I also looked for some wood treatment stuff but all they had was
Behr waterproofing and thompsons water seal.
Old 11-29-2006, 03:58 PM   #12
at_wanderer's Avatar
I used to build salt water aquariums out of 3/4 exterior ply and 2x4 framing. The joints were sealed with two part epoxy resin. Then I put 3-coats of two part epoxy paint over that. The paint was called "Plast-kote" and I think it was made here in Tampa by Pilgrim Paints.
Now I haven't used this on a trailer floor, but am considering it.
The aquariums were water tight for a minimum of fifteen years. At that point, if we had reason to drain the tank we would sand it down and apply a single coat good for another 15 plus. I figure if the stuff lasted with all that water pressure trying to pull the joints apart it should do fine as a waterproofing for sheet application.
at_wanderer is offline   Reply With Quote
Old 11-29-2006, 04:05 PM   #13
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
That's great I built tanks too!
I think it was the epoxy that did most of the work.
Old 11-29-2006, 06:03 PM   #14
acton
Okay, Im at the point of trying to get the old floor out and am not sure if I can get it out whole, I doubt it. What do you guys recommend as far as making a pattern for a new floor just in case?
Thanks again guys
Getting on top of my Airstream...? janars Roof 25 10-22-2006 10:02 PM
Recommended shocks for a 71 Overlander? ecomstock Shocks 17 08-17-2006 11:03 AM
Is Windish RV Ctr near Denver Recommended? sarmimi Commercial Listings 7 07-16-2005 11:27 AM
It's here! It's here! Hit'the'road 2002 - 2005 International 54 11-30-2004 10:00 AM
Member Recommended Repair Facilities COArgosy78 Commercial Listings 4 10-17-2003 09:31 PM
