Old 05-06-2015, 07:23 PM   #1
1975 31' Sovereign
Davin , West Virginia
Rear separation fix fail?
We followed the instructions for repairing the rotten floor in our rear bath 75 sovereign given by Inland Andy and got mostly great results. We weren't sure about how high to jack the frame before riveting but we brought it up until the old rivet holes seemed to match everywhere. The variable of course being the top seam where we had cut the quarter panel skin. More on that later. Anyway, after raising the frame and floor we checked inside and out and were elated about the closet doors not binding, the tambour doors of the bathroom cabinets aligning, etc. But the fantastic thing was that the camper door was closing and latching perfectly! So we decided to begin riveting. After a couple evenings of work we had everything riveted and watched as our son lowered the tongue so we could remove the jackstands. Pretty impressive! The tongue did have to lower a little before we could see daylight between the frame and the stands. Removed the stands, brought the tongue back to level, and the outside still looked good. The closet doors are still operating just fine, etc. However, once again, the darn door is off kilter! It is cocked upward in the opening almost as badly as before and the bolt is higher than the strike pocket. So, what to do now? Thought about removing the rivets on top and bottom and see if we can raise it again, but not sure it will work. Maybe the skin just wasn't stretched out all the way until it took on the weight of the frame? I need some pointers here, for sure.
Hillbilly75 is offline   Reply With Quote
Old 05-06-2015, 07:27 PM   #2
1975 31' Sovereign
ID:	237918   Click image for larger version
Old 05-06-2015, 07:47 PM   #3
1975 31' Sovereign
The first picture shows how far the separation was before raising the frame.
Second picture is so you won't ask if I remembered to bolt the floor and channel to the frame. Grate 8 bolts every 4-5 inches all the way around.
Third picture is under the hatch where I had to put a patch over the badly torn edge of the rear skin. You can see the caulking where the skin doesn't come completely down to the bumper plate.
Old 05-06-2015, 08:28 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
In my experience you need to be pretty aggressive with both the frame and the body because the frame will spring back, and the body will have bent down over the years.
After getting the frame right to fit the body, and the body bolted down, I was VERY aggressive with a jack near the rear frame rails of my trailer to straighten body and frame simultaneously.
After straightening I welded reinforcement to the bottom of the frame to keep what I had gained. The frame will really want to bend where it is notched for the axles.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 05-07-2015, 05:48 AM   #5
1975 31' Sovereign
Would that require removing the axles? Maybe I should drop the belly and see if there is any weakness in the frame. I guess having been flexed downward for several years could have caused a crease somewhere. What I have now is very solid. No squeaking in the floor, no movement of the bumper, just not lifted as high as I had intended.
Old 05-07-2015, 07:25 AM   #6
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Yea, I did all of this when I was changing out the axles. For my trailer this made a huge difference.
Old 05-07-2015, 09:00 AM   #7
1975 31' Sovereign
I noticed the word "aggressively". Did you raise it higher than intended so it had room to spring back some after reinforcing, or did it stay where you put it once the welding was done? Asking all these questions because I'm not a welder. I would probably be able to take it to the vocational school welding instructor though.
Old 05-07-2015, 11:03 AM   #8
Sovereign75's Avatar
1975 31' Sovereign
Oxford , Mississippi
Can you point me toward the steps you reference from Inland Andy? I'm looking at basically the same problems with my '75 Sovereign. Thanks.
Sovereign75 is offline   Reply With Quote
Old 05-07-2015, 11:51 AM   #9
Heath , Texas
Hillbilly--sorry to barge on your question but we have a somewhat similar issue and the same questions (except we actually have a small crease/bend behind the axle that causes similar "alignment" issues).
What J. Morgan has posted makes total sense to me (at least given the nature of the bending situation on my own trailer which isn't just a little bend might be different for yours). Here is my question--if Hillbilly has fixed his rear end issue and reattached the frame but can't weld reinforcements there "in place" and has to take it somewhere for welding--doesn't the bouncing up and down even further stress his rear end repair job? In other words, if the trailer is prone to returning to its drooping state even in his case where his trailer was just sitting in place, then wouldn't it naturally tend to stress his frame to skin reattachment even more in transit? And when you take it to a welder how do you explain to them exactly what "level" you want the trailer to be (post reinforcement)?
Thanks all
sailormom is offline   Reply With Quote
Old 05-07-2015, 01:25 PM   #10
1982 27' Excella
Huntsville , Texas
Reason for separation
I have heard about this, in regards to rear bath. Has the cause been identified? Is it metal fatigue over time miles? water damage? a design issue related to the weight of the tub?
GMarugg is offline   Reply With Quote
Old 05-07-2015, 05:54 PM   #11
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
What gets these trailers is rough roads and worn out axles.
I had my truck hooked to the trailer and I used a big bottle jack about three feet from the bumper of the trailer and I lifted aggressively on each side several times.
My goal was to lift until I had the bow in the sides over the wheels gone.
I was mostly successful.
If I remember I will shoot some pics tomorrow.
This DID straighten the trailer, frame, shell, and everything.
Old 05-07-2015, 06:00 PM   #12
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
If a person didn't have to go far over rough roads the shell wouldn't come back down much I don't think, but I did weld my supports in while it jacked up in the rear.
So far I have kept all I gained, and it is no longer downhill into the bathroom.
I am sure that this procedure is not without risk, but it worked for me. Frankly it is amazing how strong these trailers are when they are buttoned up.
Essentially I was lifting the trailer from the jack to the hitch, and then going inside and jumping...
I am interested to know what it would do with the crease.
Old 05-07-2015, 08:08 PM   #13
Heath , Texas
Thanks J Morgan! If we try it we will let you know.
Old 05-08-2015, 10:47 AM   #14
1975 31' Sovereign
Sovereign 75, here is a link to the thread on this subject I found most helpful. Look for the instructions a few posts from the top.
http://www.airforums.com/forums/f353/rear-end-sag-educate-me-please-22906.html
Rear End Separation Permanent Fix? dmand001 Repairing/Replacing Floor &/or Frame 23 07-24-2017 02:12 PM
Rear End Separation Short term fix? Silverflames Repairing/Replacing Floor &/or Frame 63 09-08-2013 06:05 PM
rear end separation fix ewaegeman Repairing/Replacing Floor &/or Frame 4 09-22-2012 09:59 PM
Floor/frame separation fix - section or all at once? GlobeTrottin Repairing/Replacing Floor &/or Frame 11 05-12-2011 07:21 PM
Rear Separation and Rear Sag on my '72 mello mike Axles 17 06-16-2005 01:58 PM
