Originally Posted by CraigCam
I have removed the subfloor of my 1970 overlander and noticed the rear hold down plate (angle iron) is almost a 1/4" higher than the rear cross member below it. Since the subfloor sits on top of the hold plate it would not be level with the rest of subfloor. Am I missing something or is this normal?
Hope this makes sense?
On my 74, the crossmember that the hold-down plate sits on was lower than the frame rail by the same thickness as the hold down plate. Without the hold-down plate, the subfloor would have bowed in the middle in that area.
Check where the crossmember hits the frame rail. Is it lower?
