Old 04-25-2014, 08:23 AM   #1
Cannon Falls , Minnesota
Rear Frame Replacement Height
After removing the floor on our 79 Sovereign, we noticed the frame was rusted badly. The previous owner 'repaired' the situation with a wooden subframe. We removed the back 4 feet or so and had a professional welder build a new frame, along with replacing some outriggers. My question has to do with the height of the frame. Currently, the rear end of the frame and shell are a half an inch or so apart. Should the shell rest on the frame when not on jacks? Or does the strength come when all are tied together? I'd rather have the welder shim the frame properly now before installing the floor and securing all together. All comments welcome!
minnguy is offline   Reply With Quote
Old 04-25-2014, 08:28 AM   #2
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
The floor sits on top of the frame and the shell sits on top of the frame,
so with the floor removed you should have the thickness of the floor between the frame and shell. My floor was 5/8 plywood.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 04-25-2014, 08:39 AM   #3
Thanks AldeanFan. The channel in the rear that holds the plywood is slightly above the frame. So you are saying this should rest on the frame when unsupported? Since the original frame was in such bad shape, the welder didn't have alot of information to go on and could be off by a little.
Old 04-25-2014, 11:13 AM   #4
AldeanFan's Avatar
1977 23' Safari
On my '77 the channel sits on top of the plywood, the plywood is sandwiched between the channel and the frame. I have a U-shaped channel with the open end up.
If your floor fits in the channel then there should be no space between the frame and channel with the floor removed.
Old 04-25-2014, 11:14 AM   #5
AldeanFan's Avatar
1977 23' Safari
Also there is a rear hold down plate that rivets to the shell and bolts to the frame, this is very important.
Old 04-25-2014, 12:53 PM   #6
Yes the plate must be what I referred to incorrectly as the channel. It is different than the side channels. I'll be sure to secure the plate to the new steel. Thanks for the advice.
Old 04-25-2014, 12:59 PM   #7
1981 31' Excella II
New Market , Alabama
There is an L-shaped steel plate that is riveted to the center part of the rear skin. This is different than the Aluminum C-channel that the skins are connected to. The floor will sandwitch between the C-channel and the steel plate. Bolts go through all three of these and then into the rear cross member.
Perry
Old 04-25-2014, 02:07 PM   #8
Perfect. Thanks PerryG114.
Form rear curve for frame off floor replacement Aviator Repairing/Replacing Floor &/or Frame 11 02-26-2014 04:30 AM
Lost height in rear bathroom. Help. rippie Upholstery, Blinds, Walls & Interior Finishes 4 02-25-2014 04:31 PM
Problems setting rear air bag height montreal Classic Motorhomes 6 10-24-2012 12:42 AM
Beatrice era frame experts if you please. Odd frame issue Kevin245 Repairing/Replacing Floor &/or Frame 5 08-25-2012 09:55 AM
Frame Repair or New Frame muddy_hollow Brakes & Brake Controllers 14 09-26-2006 05:55 PM
