Old 03-10-2008, 09:30 PM   #1
Olielulu's Avatar
Profile:  1972 25' Tradewind
Port Orchard , Washington
Images: 14
Rear floor replacement
Well, I've been reading the forum for about 6-7 months now since I bought my 72 tradewind. I've had a chance to do some minor repairs using the threads that have been posted. Without this forum, I probably would have been inclined to get rid of my trailer, but with all the information here, it makes everything seem a little less scary.
I've jumped in with both feet now and I am getting ready to replace the rear floor panel since it has already started removing itself. This started of with just replacing the black tank, but as soon as it came out, I knew I couldn't put it back in without fixing the floor. I now have a nearly empty rear half of a trailer, with only one big whoops. (I busted a hole in the sink while trying to get it out. The sun really made the plastic brittle.)
Hopefully when I start pulling up the floor and banana wrap, I won't find more work , but I've seen all the other threads, so I'm not too optimistic. I'll try attaching pics and updating as I move along.
Again, thanks to everyone for posting all the information that has been making this a little less painful mentally.
ID:	55987  Click image for larger version
ID:	55989  Click image for larger version
Olielulu is offline   Reply With Quote
Old 03-10-2008, 09:45 PM   #2
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Welcome!
Like you, the forum has saved me a ton - both in terms of money, frustration and time.
Nice to have you here.
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 03-10-2008, 10:01 PM   #3
Commercial Vendor
Profile:  Corona , California
Your brittle bath sink can be fixed.
The holding tank is available from us, but made with fiberglass, that eliminates the cracking problems.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Old 03-11-2008, 09:52 AM   #4
vhord's Avatar
Profile:  1970 27' Overlander
Crosby , Texas
Images: 95
What is the proper way to fix it? I applied some fiberglass resin to the back side and it appears to be sticking good and did not attack the plastic. Is fiberglassing the best or is there a better or easier method? The PO cut these two knotches out of the toilet surround to put in a house toilet tank and I do not have the pieces that he removed. Of course I will refinish them when repaired.
Name:	Toilet surround.JPG
vhord is offline   Reply With Quote
Old 03-12-2008, 09:41 PM   #5
Olielulu's Avatar
Images: 14
sink repair
Andy, Is there a thread somewhere on sink repair, or do you know a good way to repair it? I was thinking I was going to just have to make a whole new sink and counter out of something else (stainless maybe)
Old 03-12-2008, 11:58 PM   #6
Fyrzowt's Avatar
Images: 8
Olielulu, here are some ideas/info.
Fiberglass repair on my '65 Overlander sink
Bathroom Sink
Bathroom sink stained
AIR #15800
2000 Safari SS 25'
Old 03-14-2008, 12:20 PM   #7
Olielulu's Avatar
Images: 14
the work grows
Well, (I know – a deep subject for such a shallow mind) I got back to removing more of the stuff in preparation to replace the rear floor, and at some point during the process, I decided that it would be easier to just remove everything from the trailer and fix all the little things. Plus while I was out there, it just happened to be raining up here in the northwest, and I was finding signs of water leaks. Since I have to take half the trailer apart to fix the floor, why not just take the whole thing apart so that I can spend a lot more money?
The good news is – when I pulled the banana skins off the rear corners, the frame and outriggers looked good with the exception of one of the streetside outriggers that was below the water heater that was leaking for who-knows-how-long. It was almost completely rotted away.
Insulation. I have read a lot of the threads on complete restorations, and noticed that a lot of them put in a silver insulation. Is that the bubble wrap insulation that I have seen at the home stores? I’ve looked at it and can’t find an R value on it anywhere. It can’t be too much unless you layer it a bunch of times.
Flooring. I measured the flooring and it measures exactly ¾”. I’ve read everywhere that the flooring should be 5/8”. Is this just a dimensional thing like a 2 x 4 is not actually 2” x 4” ? I’ll probably answer my own question when I go to the lumber store. I’m going to try and get the marine grade plywood. I’ve read a couple threads where they used OSB, but I found a study by the university of Oregon that shows that the OSB soaks up water at the edges and expands (everyone knows that) . It also says it is slow to soak up the water, which is good, but on the reverse, it is slow to dry after soaking up water, which will help lead to rot quicker.
ID:	56201  Click image for larger version
Old 03-14-2008, 12:34 PM   #8
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 92
Careful...it's a slippery slope!
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
InsideOut is online now   Reply With Quote
Old 03-14-2008, 12:44 PM   #9
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
"Well, while I'm at it I might as well fix this too" We've all been at this point before.
Aerowood is online now   Reply With Quote
Old 03-14-2008, 01:11 PM   #10
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
do a search on the forums for "reflectix" insulation. I think thats what you're talking about. and no, you don't layer it. It works in an entirely different manner than the fuzzy pink stuff...(I can't remember the proper terms..."conduction" vs. "convection", or something along those lines), and for the most part, "r-value" just doesn't apply to it. what r-value measures, reflectix doesn't do.
no. Older trailers (60's) used 5/8ths; (older ones might have been even thinner; not sure). 70's used 3/4. I'm not sure of the exact cutoff, but I would guess 1969, as that was the year of the major body-style change.
you might run into the "dimensional" issue, though, as today, they don't sell "3/4"...or its hard to find. 23/32 is not very much thinner, and if you place that seam cleverly, no one will likely notice.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 03-14-2008, 01:31 PM   #11
InsideOut's Avatar
1956 22' Safari
Images: 92
Our '56 had 5/8" plywood plus the VAT...for a total of 3/4" under the c-channels. Since we are replacing the entire floor, but not putting the new marmoleum under the c-channels, we are putting in 3/4" marine grade plywood.
Shari
Old 03-14-2008, 02:24 PM   #12
fotochop's Avatar
Profile:  1969 23' Safari
New Orleans , Louisiana
I recently repaired the cracks in my plastic bath parts using a sort of new product from West Marine called G/Flex and it seems to work really well. 2 part epoxy with fiberglas fabric, it's semi-flexible and appears almost indestructible. The kit was only $20 plus $3 worth of fabric. Applied to the back side then filled in the depression with Interlux Watertite Epoxy Filler (also excellent), sanded smooth and painted with Interlux Brightside Polyurethane. You can also see various bath repairs (POR frame, tank welding, etc) here: '69 Safari bath floor repair
Rick Olivier
New Orleans
http://www.rickolivier.com
fotochop is offline   Reply With Quote
Old 03-14-2008, 10:42 PM   #13
Olielulu's Avatar
Images: 14
more "progress"
So, I’ve got all the cabinetry out of the trailer and will be moving on to removing the interior sheathing and insulation to start chasing down leaks. Just removing all of the interior has pointed me into about 4 or 5 locations that I didn’t have any idea there were leaks. (luckily?? it's raining again to help me with that) I'm feeling better about going all the way. This way I will have peace of mind when I finally get to use it.
I found a couple patches in the floor up forward. they used OSB. I'm attaching a photo of why I know for sure I wont be using it. It's not the best photo, but the difference in thickness between the OSB and the old plywood is about 1/16" where the leak is. The OSB is also softer when I stab it with my screwdriver (I just did that to make me feel better .)
One of the PO's must have had enormous hands because they had to cut out an extra hole to get in to the water tank area. this was covered with a thin sheet of aluminum that was then carpeted over
I also found that the inner and outer wheel wells are pretty damaged on the curbside. I'm not worried about the inner, but I will have to replace or figure out repairs for the outer one.
Exactly!! I only want to do this once. It really bugs my wife when she just want me to get something finished quickly and I keep finding more things to fix "while I'm there."
I guess I'll look and see if they have a web site. It doesn't look like it will do much good if it is freezing outside and I only have a layer of bubble wrap with tinfoil on it to keep me warm .
Thanks to everyone for all the encouragement.
ID:	56227  Click image for larger version
Name:	Nearly empty.JPG
ID:	56229  Click image for larger version
Old 03-16-2008, 02:49 PM   #14
Profile:  1972 27' Overlander
windber , Pennsylvania
Hi! I read about the silver insulation, I've used it myself in my garage and other places. I'm pretty sure the R value is 7.5 which would probably be more than the original stuff that was in there. I'm working on a '72 27' Overlander and my floor fortunately is in fairly good condition. So far my only problem area is in the bathroom and compared to yours its MINOR! I've repaired the frame in the front in a couple of spots and I'm ready to insulate using the silver bubble wrap insulation. It's adequate for the job (it won't hold moisture). Home Depot or Lowe's sales it. Good luck! Jim Turcato
jim turcato is offline   Reply With Quote
Pingbacks are On
65 floor view from rear hatch tbrom Repairing/Replacing Floor &/or Frame 3 06-13-2007 09:54 AM
63 tradewind rear floor replacement durans54 Repairing/Replacing Floor &/or Frame 5 06-09-2006 02:20 PM
Rear Floor Repair balrgn Repairing/Replacing Floor &/or Frame 26 12-22-2004 02:10 PM
Rear Bath Floor Repair trogers713 Repairing/Replacing Floor &/or Frame 7 10-26-2003 06:43 AM
Rear Bath Floor Repair trogers713 Repairing/Replacing Floor &/or Frame 1 10-24-2003 08:30 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
Airstream is a
