Old 05-10-2012, 09:32 AM   #15
1969 27' Overlander
Lenoir , North Carolina
The floor is full of elevator bolts and screws. My floor wasn't as bad as it looked. Around the water heater and the very rear where rotted,,,,but this rest was a b!)%# to get out....very solid. I thot i was gonna do a quick fix until i got into it. I told my wife it would be ready by July. Now it's a full blown shell off floor.
ProWelder is offline   Reply With Quote
Old 05-10-2012, 12:10 PM   #16
195Pilot's Avatar
1975 31' Sovereign
Pierre , South Dakota
Keith,
I am in the process of fixing what someone repaired with the above described repair,patch solutions. Cutting the rear panels and then adding additional POP RIVETS destroys those panels. Yes there patched but panels are cut and with all the extra rivets its like swiss cheese when you finally go to make the proper repairs.
At some point you will be correcting the problem then your looking at replacing the rear quarter panels.
Inspect the frame and tank support area, if there sound seal the rear area as best you can then when you have the time do it right.
195Pilot is offline   Reply With Quote
Old 05-15-2012, 09:55 AM   #17
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Here are some pics.. You can see the rusted crossmember on the second to last pic. All the bolts have broke free at this point.
ID:	158461   Click image for larger version
ID:	158463   Click image for larger version
Silverflames is offline   Reply With Quote
Old 06-21-2012, 12:27 PM   #18
garthbf's Avatar
1975 31' Sovereign
1960 26' Overlander
Mount Vernon , Washington
here is my fix...
http://www.airforums.com/forums/f36/...ing-45324.html
garthbf is offline   Reply With Quote
Old 06-23-2012, 08:23 AM   #19
1969 29' Ambassador
Thank you garthbf, you post shows me almost every thing I need to know. How long did the job take you?
Old 06-27-2012, 12:04 PM   #20
1969 29' Ambassador
Looking over Garth's job, I was wondering if the hatch could be left on, and just remove the door, and the few rivets on the side of the hatch, leaving the main hatch ring on the center piece.
Old 06-28-2012, 10:27 PM   #21
1969 29' Ambassador
Well I started to pull her apart.. Like many threads I read, lots of rust and rotten plywood. It looks like I need to replace some of the main frame rails, and out riggers while I'm at. I'm still struggling with fixing it right, or just patching the bad sections of the frame... The real question is how much time do I want to put into this. The good news is that I have the main frame channel left over from when I fixed the front section of frame. Overall the cost is low, just takes a lot of time..
ID:	161991   Click image for larger version
Old 06-29-2012, 09:06 PM   #22
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
Nothing a little duct tape won't fix! Good luck.
ddstech is offline   Reply With Quote
Old 07-01-2012, 07:25 PM   #23
1969 29' Ambassador
Just a quick up date to the "Quick Fix" I waned to do. I got the old main rear frame rails cut out, and replaced them with .25" Galv 5" c channel. Welded them in place, and then cut out support bracket/c Chanel under the back hatch. The entire thing was rusted into one solid piece. I'm debating on how to put that section back together. I'm going to use .25" Galv angle iron for the cross member, but I'm not sure if I should build the c channel out of Galv steel and weld it to the cross member, or buy an stainless steel or aluminum c channel and just bolt through the three layers.. Any ideas? If it has to get redone again, I want one of my grand kids to have to do it...
ID:	162199   Click image for larger version
Old 07-01-2012, 08:35 PM   #24
Eric H's Avatar
1974 23' Safari
1947 25' Spartan , Manor
That's a hard call. The one thing I would not do is sandwich aluminum up against it. First off it won't have the strength, secondly it will corrode the steel even faster.
It would really depend on how bad the C is. If it's badly rusted with holes then I would find a way to do a full repair. Not to mention if the floor is rotted out. The floor is part of the structure when it's all pulled together, shell, floor, frame. Perhaps you could just pull up the back section of floor to get to the frame....that's still a lot of darn work.
Eric H is offline   Reply With Quote
Old 07-11-2012, 10:45 AM   #25
1969 29' Ambassador
Well it's been a Bad week working on the old girl. I'm not to sure if I should post this or not, since I still feel like a complete idiot. I was welding on frame replacing rusted out section. I did think I needed a spotter, but now I know better. I was welding underneath and noticed smoke coming out of the water heater door, jumped up to discover the back driver side bathroom caught on FIRE!!!!! Grabbing the water hose I opened the back hatch and started spraying like crazy. The old plastics in the bathroom went up like a bomb fire. I was able to put the fire out saving the trailer... Sadly, the whole bathroom will need to be redone, the whole inside of the trailer has smoke damage and will need to be repainted.
So at this point I will be doing a full bathroom rehab, including a new floor, sink, closets, etc.... Looks like the summer camping trip is off.. My wife is great and stated "well now we can fix it all right, and it will look great when we are done.".
ID:	162923   Click image for larger version
ID:	162925   Click image for larger version
Old 07-11-2012, 11:36 AM   #26
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Thanks for posting - do you know what was the original point of ignition? Vulkem caulk? Mouse nest? Pipe insulation?
It took grit, guts, and lots of heart to share that. Sure makes for excellent clarity on the task before you though?
I once answered a telephone just as I'd started brazing a patch on my 1973 Pinto quarter panel, a minute later looked out the window to see column of smoke and fire. Whoda thunk the wheel well brace bracket in there was plastic? Good thing the fuel filler was on the other side.
Best of luck getting some Fall camping in!!
Old 07-11-2012, 11:44 AM   #27
1969 29' Ambassador
From the location of the fire, I think sparks from the angle grinder might have made their way to some old carpeting. I had a box fan running behind me to blow away the gasses coming off of the galvanized steel, and I'm sure that it helped things along. Next time I'll have a spotter and I'll soak everything down before I start.. We live and learn..
Old 07-11-2012, 11:48 AM   #28
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
That really sucks, but I could be a good excuse to pull the shell off.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
